Any bipedal creature needs this crucial part...
01/23/2023 at 19:38 • 2 commentsI have started to tinker with ROS and Gazebo to implement what will be the most crucial part of the robot: Its brain!
A walker needs legs!
02/12/2021 at 00:15 • 0 commentsFinally, the bottom part of my biped named Walk-R is now done. After countless redesign and re-prints, here it goes!
I will now spend my time researching how best to make it alive.
The next steps:
- Integrating the MPU-6050 to the RPI4.
- Doing balancing tests
- Doing simulations in ROS Gazebo to study possible algorithms for balancing.
That's it!
Stay tuned!
Hardware changes (again)
07/11/2020 at 00:28 • 0 commentsI finally got sick of battling with the XL-320, OpenCM and Pixl boards. It was either not working under Linux or not working with more than 6 servos.
So, I looked up for something else and after a while, my choice stopped on the LewanSoul servos. So far, they meet my expectations. I have 1 leg done (minus the foot, which requires a redesign) and I'm waiting for the next batch of servos to come at my door.
Stay tuned, as I will show up where I'm at when the second leg (and hips) is done!
Hardware changes
03/25/2019 at 16:35 • 0 commentsI've begun to port the thing from the OpenCM to the Raspberry Pi, using the Pixl board.
I still have issues with it, though. Next post should be when I have solved those issues and have a robot standing on its own two legs!
Next goal: A self-balancing biped bot...
stefane.lemay
