Cone Winder Software uploaded on github (19.12.24)
I have built a cone winder (based on the concept of Schönflies Motion) because commercially available cone winders for hobby knitters often fail to wind yarn flawlessly. This can cause significant issues when using electronically controlled knitting machines with motors. To address this, I designed and built my own cone winder.
The cone winder has been operational since early 2023 and works perfectly. It supports cones and cylindrical spools of various sizes. However, it is still missing sensors to detect the left and right endpoints and a button to stop the motors manually.
The yarn I use measures normally between 15,000 meters to 30,000 meters per kilogram.
The project is still in progress.
The control software for the cone winder (using Bresenham's Line Algorithm) is now available on github: https://github.com/IrenePassap/Cone-Winder-Control-Software/tree/main
Yarn Winder - Cone Winder, new Video on youtube (6.2.23)
The XY axes move like the TBot (see the video below).
Video TBot
New Video on youtube (29.12.21)
The Video shows the setup, how I write a simple Jacquard technique in part 1. The second part shows how the machine knits and the swatch.
I will upload the new software version in the next few days on Github. I've revised the code and the GUI. I have also improved the error messages.
Passap E6000 is a computer-controlled knitting machine. It has two needle beds. Each individual needle on the front needle bed can be controlled via a console. The needles on the rear needle bed are controlled mechanically. I have always dreamed of being able to control the rear needles via the computer as well. I knew it was somehow possible but had no idea how. The essential idea came from Hackerspace Bamberg (https://www.hackerspace-bamberg.de/Passap_pfaff_e6000, https://github.com/knitty/firmware/tree/master/software/Knitty ). The hackers have exchanged all parts from the back-needle bed with those of a front needle bed. For the new rear needle bed, a second front lock has been rebuilt.
_______________________________________________________________________________________________________________
Juni 2021 New Version
Video and photos of the console, the motor controller unit and interface.
If you would like to find out more, just ask.
Same mounting as the original console
Back of the console
Rear lock
Motor, window for the frequency converter. On the left: Motor interface. Black cable on the top of the red enclosure is the USB connection to the console.
frequency converter
Mounting frequency converter
Motor interface. Owen made the design of the board according to the previous interface, thank you Owen, the interface looks now much nicer. The Arduino is now on this interface.
Passap Electra 4600 rebuilt (2020)
In the video below (2020) you can see the knitting machine and the motor Electra 4600 in action. More detailed information will follow over the next few weeks.
What is new?
The electronics of the Passap Electra 4600 motor have been replaced by a frequency converter, an interface and a controller. More project details will follow over the next few weeks. The latest version of the software will be published on Github. I hope this information will help you to realize your own project.
Electra 4600 connected to the frequency converter
I actually wanted to integrate the Electra 4600 engine in my project. Unfortunately the Electra 4600 engine had malfunctions. The control circuit board was damaged. We couldn't find out if more was broken....
Irene Wolf
Norbert Heinz
Adam Wakelin
MasterOfNull
Giulio Pons
Sometimes searching on YouTube helps; now I've found a tutorial:
https://youtu.be/DWB4ooJ4CYg?si=Noh9avF2EGZWZ1Uo
Wbr Winfried
