Features:
- Wind speed
- Wind direction
- Humidity
- Pressure
- Temperature
- Battery volts
- Soil moisture and temperature
- Rain (even in deep sleep)
- LoRa connectivity
- Adafruit Feather M0 MCU and radio module
- MCU watch dog (auto reset if MCU crashes)
- Full Deep Sleep (everything is turned off between taking readings)
- Arduino IDE (easy to program)
- Hacking zone for extra circuits
- Spare RJ25 slot for cheapo wind instruments (if you really must).
- Server based PHP driven GUI
My previous version of a weather station used 2G GPRS for the data transmission which proved to be very power hungry and, even with a 40 watt solar panel, went dead during the dark months of December and January. The other problem was that, every now and again, the GPRS server would decide to kick the sim card off the network which sometimes required the card to be removed, inserted into a normal phone and an 'upgrade' downloaded. Moving to 3G or 4G would not solve these problems, even though 4G is far less power hungry.
I decided to create a new version of the control system based on LoRa technology which could potentially send data straight to a LoRa gateway if one existed. Unfortunately, I live on an island in the middle of nowhere so there's no chance of a gateway in the foreseeable future so I had to build a LoRa receiver as well.
Other than power requirements and data transmission, the main focus of this project is getting accurate wind measurements using high grade instruments and sensible positioning of those instruments up the top of a pole.
So why use these expensive wind instruments?
The generic wind vanes use eight sets of resistors to give a basic resolution of 45 degrees which can be further refined by using averaging, but wouldn't it be great to have 360 degrees (or better) resolution? The generic wind anemometers are 'ok', but don't last very long before the bearings need changing and are not calibrated so we have no idea how accurate they are.
On a positive note, the cheap generic rain gauges are actually very good and having tested them for over 3 years, the only problem was spiders running up and down the rocker arm playing some kind of game of chase and then getting bored and creating a web to seize everything up. They just needed a quick clean every six months or so.
One of the things that worked really well in the previous version of this weather station was the code for the wind instruments. The anemometer was relatively simple to implement as I could use a simple 'pulsein' command although, technically, this is 'blocking' and will introduce an unwanted delay in the code speed. Also, the rain gauge could theoretically interrupt the pulsein midway during the process causing an error so pulsein is wrapped in 'nointerrupts'. We could still miss rain readings, but this is helped by the fact that the gauge triggers twice per reading so we can filter for one or two interrupts in the code, dramatically decreasing the chances of missing a reading to 'almost' zero.
The wind vane is far more complicated to code as it relies on polar coordinates (0 to 360) which means that normal oversampling and averaging using the 'mean' is not possible. Think of the situation where the wind is blowing from the north ...... one moment we get a reading of say 2 degrees, the next a reading of 355 degrees which would give a mean value of approx:
(2+355)/2 = 180
To overcome this I had to use 'mode', which necessitates creating a large 1D matrix of possible values and then evaluating which ones were most common over a particular time period. This...
GOAT INDUSTRIES
The two low flat spots in the graph above show where I tested the rain gauge. It works!
... and the average power, and average current = 3.2 uA ....... Nothing to worry about! It's probably more like 1.0 uA due to the fact that the capacitor does not discharge to zero unless it rains.
..... and we've got nice, quick, clean transmission spikes and deep sleep of 2 mA. Steady state of the MCU is 11.5 mA. The smaller spikes in the deep sleep zone are caused when the Sleepy Dog wakes up momentarily every 15 seconds or so to have a quick look around in case there are any cats to chase. There's no way around this, it's just how it works, but it's quite handy to flash an LED for about 2 ms here just to indicate that the device is still alive.
The first section is stainless steel 1" as above and is concreted into the ground.
The wind vane is mounted as above. The last section also has the guy rope attachments and the Anemometer
k
Jeff Taylor
Very nice project, if only I had this know how and ready access to today's SOC boards 15 years ago as a grad student. I deployed and maintained these in remote locations and I was constantly worried about power requirements punching holes in my data collection. I wish I met LoRa at that time life would have been so much easier.
