ORDERING THE PCB
I would also recommend to get your PCB manufactured at least 2 pieces. You can order your PCBs from PCBWAY as they offer 10 PCBs for just 5$. Check out their online Gerber viewer function.
This PCB is a single channel gateway of LoRa, You can use this PCB as a node as well.
ORDERING THE PCB
Gerber_PCB_HACKSTER_20190225205341.zipx-zip-compressed - 300.77 kB - 03/01/2019 at 12:53 |
This PCB is a sinle channel gateway of LoRa, You can use this PCB as a node as well. The Pcb uses:
There is also an easy to program header under the OLED display to flash the device by connecting FTDI chip.
ORDERING THE PCB
This device will connect to the internet with wifi. Do you think of wired internet or LTE connection?
Hi,
Hello there. Is the product assembled? Have you considered an external box design?
1. is mesh?
2. is possible using this with solar panel?
3. please add normal usb host A for pendrive and storage
