LoRa gateway single channel PCB
This PCB is a single channel gateway of LoRa, You can use this PCB as a node as well.
This PCB is a single channel gateway of LoRa, You can use this PCB as a node as well. The Pcb uses:
1.ESP8266 as the microcontroller
2.Ra-02 LoRa module.
3.OLED SSD13086 0.96' display
4.Other basic components.
There is also an easy to program header under the OLED display to flash the device by connecting a FTDI chip.
Checkout UTSource for electronic components for your DIY Projects with free shipping: https://www.utsource.net/
ORDERING THE PCB
I would also recommend to get your PCB manufactured at least 2 pieces. You can order your PCBs from PCBWAY as they offer 10 PCBs for just 5$. Check out their online Gerber viewer function.
Gerber_PCB_HACKSTER_20190225205341.zip
x-zip-compressed - 300.77 kB - 03/01/2019 at 12:53
Download
  • 1
    Get this PCB manufactured!
    LoRa-gateway-single-channel-PCB
    FRONT SIDE IMAGE OF THE PCB
    This PCB is a sinle channel gateway of LoRa, You can use this PCB as a node as well. The Pcb uses:
    • ESP8266 as the microcontroller
    • Ra-02 LoRa module.
    • OLED SSD13086 0.96' display
    • Other basic components.
    There is also an easy to program header under the OLED display to flash the device by connecting FTDI chip.
    ORDERING THE PCB
    BACK SIDE IMAGE OF THE PCB
    This is the schematic for the project:
View all instructions
teraz wrote 01/19/2022 at 19:14 point
1. is mesh?
2. is possible using this with solar panel?
3. please add normal usb host A for pendrive and storage
ressamendy wrote 06/19/2019 at 13:16 point
This device will connect to the internet with wifi. Do you think of wired internet or LTE connection?
ressamendy wrote 06/19/2019 at 12:46 point
Hi,
Hello there. Is the product assembled? Have you considered an external box design?
http://prntscr.com/o3vhtw
