Universal Touchscreen
Let's turn every surface into a Touchscreen on the cheap !
cmcCmC
Every time you touch something, you are giving the touched surface mechanical energy. This energy can easily be recorded by a simple microphone. The idea is the following : let's record what is happening inside the touched material and try to locate where the energy is coming from.
How do I measure the impact of a finger on a surface ?
I am using a piezo sensor. It is cheap, reliable and easy to interface. Also it does exactly the job it is meant for : it gives an image of the mecanical energy at its surface.
What surface do I use ?
Every experiment I am doing is made on a piece of glass. Approximatively 30cm*20cm.
System overview :
I made a video explaining a little what the system is all about :
  • 4 × Piezo Sensor
  • 4 × Dual Op Amp
  • 1 × PIC18F4550 Microprocessors, Microcontrollers, DSPs / Microcontrollers (MCUs)
  • 4 × LDR Resistor Networks / Thick Film Networks
  • 4 × White DEL
View all 7 components
  • USB link, a first version
    CmC • 08/21/2014 at 06:42 • 0 comments
    As it turns out, making a stable USB link is not as easy as it might look. I would like to emulate a mouse with the pic18f4550, I am still seachring how ! In the mean time, I am using the HID library in Mikroc for Pic which simplifies everything !
    Actually, I am able to send data through the usb port ... getting in the right track !
  • Basic principle
    CmC • 08/19/2014 at 07:43 • 0 comments
    What happens when you touch the surface ?
    - The mechanical energy propagates inside the material
    How can the piezo find out where the finger landed ?
    - Using the time of flight :
    The energy wave arrives at the different sensors at time t1, t2 and t3.
    The only problem is that you cannot determine t1 as there is no t=0s origin.
    If there was a way to find t1, you would only need two piezo.
    The only information we can find are the time differences. But that's more than enough because every time difference describes a hyperbola which goes through the point where the energy wave came from. The intersection between the 3 hyperbolas that can be drawn gives you an unique point : the origin of the energy wave.
  • Analog signal processing
    CmC • 08/19/2014 at 07:19 • 0 comments
    The signal comming from a piezo is really uneven. First of all in order to be able to compare the signals, they need to have some similarities. I
    found that the signal is almost a sinewave (with decreasing amplitude). Here is a screenshot of my (little) oscilloscope :
    My idea was to rectify the signal so that I only have to care about amplitude.
    I used a rectifying bridge (Gretz Bridge) in order to do that.
    What a noisy signal !
    After passing it through an amplifier and an RS latch :
    Now we are talking !
  • USB Communication and calculations
    CmC • 08/19/2014 at 07:07 • 0 comments
    In order to calculate where the finger touched the surface, I needed a powerful enough microcontroller. It also had to support USB in order to be able to communicate to a computer. I am planning to emulate an HID mouse with the microcontroller. I had a PIC18F4550 lying around with seems to fit to the requirements : it supports USB and has plenty of RAM !
    But I cannot connect the piezos directly to the microcontroller, I first need to process the signals and make them a little more readable !
  • Maths and Electronics are done !
    CmC • 07/21/2014 at 07:50 • 0 comments
    Finaly the maths behind everything are done. Electronics are also done but I am planning to change the whole thing, the second version is in progress.
View all 5 project logs
arun.mukundan wrote 10/30/2015 at 12:15 • point
Hey! Great Project! I want to try to make my entire desk a touchscreen :) May I ask which piezo are you using?
aelias36 wrote 08/16/2014 at 06:46 • point
How will a piezo be able to tell where it was pressed?
CmC wrote 08/19/2014 at 07:22 • point
Well only on piezo won't be able to tell where it was pressed. Indeed you need 3 piezo. You have to compare the time arrival in order to find out where the finger landed ! I will publish the maths as soon as possible.
