Cyborg Eyeball Project
Your eyes make the light
Have you ever been working on a project and it seems like no matter what, you are always working in a pesky shadow? Have you ever thought your looking spheres appeared a little outdated? Perhaps you thought, "Damn, I am getting really tired of having these perfectly, clear, unscratched, corneas."
Well if any of the above has applied to you then, look no further then the Cyborg Eyeball Project (aka, the Eyeball Killer project). Imagine if your eyes not only absorbed light but *emitted* it too!
This started out as somewhat as a joke/what-if and has since turned into a torture test for OSHPark's flexible PCB manufacturing abilities. If it works, and you can stand the pain and discomfort, then something like this could really be useful and look pretty badass.
After watching the talk on diffractive optics from the HaD Superconference a while back I started thinking about some next gen VR display stuffs. The usual pondering. I was looking around the interweb and seeing what sort of ideas people may have about this tech and I found Applied Science's video (opens in new tab) where he mounted an LED inside of a contact lense and then wirelessly powered it. Obviously it wasn't going to be feasible for the sci-fi HUD  that we all someday dream of having, but at least it was a start. Of course, that video was made more with the idea of eye-mounted displays in mind i.e. shining light into your looking spheres. That got me thinking, what if you had light that came out of your eyeballs
  • DIY Paper Thin and Flexible Circuits!
    Chris04/27/2019 at 18:08 2 comments
    I don't mean to disappoint anyone, but I still have not managed to blind myself. Sorry.
    As a bit of a refresher: to date I have taken two different approaches to trying to make this badass glowing eyeball. Both of which have had their pros and cons
    1. The custom made flexible PCB from Oshpark
      1. Professionally made and looks pretty
      2. Tough enough to handle the heat of a soldering iron
      3. Not flexible enough
      4. Hurts my eyeball
    2. The "circuit sculpture" of wires and LEDs
      1. Very flexible
      2. Much thinner
      3. Incredibly Fragile
      4. Quickly bends into a potato-shaped mess.
    What I really needed was a happy medium between the two. Something that was much thinner and more flexible than the PCB, but also something that wouldn't take me hours to hand solder, and then be ruined at the slightest of man handling. Even more so, a process that was repeatable and easy enough for the home gamer would be ideal. I thought about various approaches for quite a while (nearly a month according to HaD), and I think I finally found the secret ingredient - copper tape! It's flexible, super duper thin, and can be applied to pretty much any substrate of your choosing.
    What I find interesting is that copper tape doesn't exactly seem entirely commonplace, at least to me. I first encountered it in an arts-and-crafts-and-circuits type kit that my little brother got for Christmas. When I asked the nice man at the hardware store if they had any, he gave me a funny look. Apparently it can be used as some magic barrier against slugs and snails? The adhesive is also conductive, so maybe consider adding it as another tool in the toolbox.
    With a little be of trial and error, and my secret ingredient, I think I have finally found a process for making super thin circuits, that hopefully some of you may also find useful.
    Anyway. Let me show you how to turn some paper and copper taper into a circuit board that sits on your eyeball.
    Obviously, the first thing that  to do is get yourself some copper tape. It seems to be most commonly available in 1/4" and 1/2" flavors. I used 1/2".
    After that I needed to actually design the circuit board. For my very first prototype (the board made by OSHPark), I used plain 'ol Eagle. However, as some of you may know, Eagle tends to be a little less than user friendly when it comes to curved shapes. So this time around I opted to use Inkscape. The program is commonly used by hackers to generate vector files for laser cutting and the like. I whipped up the board in a fraction of the time it would have taken me to do it in Eagle. It looks like this:
    The whole thing was about 10mm^2. The little round bits nubs towards the bottom are  where I soldered the leads wires, and each of the radial tabs are size 0603(1608) SMD pads. The plan here is that the soldered LEDs connect the inner ring to the outer ring, that way I don't have to worry about getting rid of any extra support connections later.
    From there I then copy and pasted my design a whole bunch of times and printed out a test page to give myself a template as to where to put the copper tape on the paper.
    After putting down the copper tape in the right place, it's just a matter of running the paper through the printer again!
    As you can see below, the designs on the left and the right didn't print very well. By laying down strips of copper tape and printing a whole bunch of designs at once , there is a much higher chance that I will get some userable designs.
    Fortunately, if you don't feel like cutting and laying down a whole bunch more copper tape a little bit of acetone wipes the ink right off and you can reuse the same paper!
    I cut them into bite size little pieces!
    Then a quick bath in some Ferric Chloride
    Now we are left with just the toner, tape adhesive, and the paper. The tape adhesive being the reason why there is still a white rectangle around the design.
    The surprisingly tricky part of this...
  • The Tiniest of Circuit Sculptures
    Chris04/01/2019 at 21:09 0 comments
    In this exciting installment I continue to find new ways to possibly mutilate my eyeball, and I am unfortunately foiled!
    From experimenting with the first prototype it was pretty clear that one of the first hurdles that must be overcome is the overall flexibility of substrate that the LEDs are placed on. The PCB is far less flexible than that contact lenses, and as such, the contacts are not able to force the PCB into the proper curved eyeball shape
    First, let's rewind a bit. As I mentioned before, one solution to this issue would be to get rid of the PCB entirely (but then I don't think I could enter into the flexible PCB contest ;D). For those of you playing along at home, you will remember that my first attempt to dead-bug solder some leds into a ring did not go so well.
    This was using 0603(1608) SMD leds. They were crusty and didn't actually work. For some reason, the solder just wouldn't wick onto the wires, making it near impossible to actually attached the lights. I even made sure to burn off the enamel coating and everything! Once again, for those keeping track, it was a this point where I decided to have the PCB made, which is what you can see in my friend's eyeball featured at the top of this project. The thought of a substrate free design still seemed like the most feasible option though. So I ordered some more leds and decided to give it another shot.
    This time I stepped it up notch though, and attempted something only fools would think about....I used 0201 (0603) LEDsThat's right. I attempted to open air solder some of the smallest LEDs that money could buy. I guess I technically succeed? Before I show you the final result, let me first show you my method, because I think it was pretty clever.
    I quickly realized that the biggest issue that I was going to have was holding everything in place all at once. Thankfully, my good ol' friend Mr. Electrical tape came to the rescue. I placed once piece of tape sticky side up, and then tape it down on either side. This then gave me a nice sticky substrate that I could arrange my sand-sized LEDs on. Once they are in place, I can then go around to each and gently place a tiny amount of solder on them, working around in a circle one by one. It was soooo much harder than it sounded
    I think it is kind of fun to look at the tweezers for some sense of scale. These were the smallest LEDs that I have ever worked with, and the whole process really helped me work on my mediation skills. All told I think I spend around 8 hours solder, breaking, adjusting, and fixing the solder connections. This is one of those things were you really want to nail the whole thing on the first go around. The more you futz with it, the crustier and more kinked everything becomes. I started over countless times until I eventually ran out of LEDs.
    It is also worth noting that I switched my choice of wire as well. Rather than using hair thin enameled copper wire, I instead used some slightly thicker strands of wire that I extracted from an old IDE cable. This seemed to take solder much more readily, but it did increase the overall stiffness of the assembly.
    At the end of the day this was the final result.
    I am a bit disappointed that after all that work I couldn't get a better result. I have a feeling that if I had just one more shot at it I could have gotten something more presentable. However, everytime I went to set it up, I either accidently smashed it out of shape, or broke one of the solder connections. Regardless, I think what I was able to make has a very cool vibe to it. The LEDs are plenty bright enough despite being so so tiny.
    This endeavour has also been pretty enlightening for the next steps I need to take. I still think that the dead-bug style cyborg eye has some potential when it comes...
  • Welcome to the future
    Chris03/25/2019 at 02:06 0 comments
    My first attempt was a bit of a misguided way to spend a Friday night.
    I had bought some super thin enameled copper wire and blue 603 smd LEDs with the thinnest profile that I could find. Based on the Applied Science video, it seems like one of the biggest issues that he ran into was the thickness of assembly. Keeping everything nice and slim is going to be the real name of the game here. I figured that the best I could do would be to solder some leds in parallel Jacob's Ladder style, and then bend the wire into a ring. Once that was done I would then seal it between two contact lenses, leaving the wires poking of one side.
    As you can see, that didn't work too well. I learned pretty quickly that bending straight things into a circle is generally pretty hard to do. This was pretty discouraging because I figured that this was my best chance at getting the thinnest lense assembly possible. I think that in the future I might try this approach again, but at this point I was getting sick of dealing with all these fiddly wires and opened up Eagle to vent my frustration into.
    My intention was now to create the smallest and most flexible PCB that OSHPark would attempt to make. After eyeballing some measurements (heh), I whipped up a ring with leds evenly spaced and wired parallel . Unfortunately I lost the file, but not first before having a few made.  The final result is below, with the 602 led in the middle for scale.
    I was a bit nervous about how bright these little guys were going to be. I had to try to optimize voltage, luminocity, and thickness. Ideally the LEDs are just going to be wired up to little 3v watch batteries stuck to the side of the uses head. Unfortunately, the wires coming out of your eyeballs are going to hurt like the devil. The problem is that there really just isn't enough space on your eyeball to make the whole wireless power transmission work well. So killer eyeball wires it is!
    Once I soldered everything and hooked it up, I was incredibly impressed with how much light these little guys put off!
    (Sorry for the shaky picture, I was just so excited!)
    Now obviously the electronics side of this project was pretty trivial. So now it is more of a matter of how to actually get this light ring in your eye, thus catapulting you into the cyberpunk world of your dreams.
    Right now the current method that we have come up with is to simply sandwich the ring into between two contact lenses. This only sort of works, and we still need to find out how to bond the two lenses together without clouding them and keeping them flexible. The other issue is that the ring should ideally be able to conform or match to the curvature of your eyeball, something either said than done. Right now method is to cut a gap into the ring, and then glue the two ends together. This causes the pcb to adopt somewhat of a conical shape, and it works to some degree. However it is far from an ideal solution.
    Either way, we did in fact manage to get a test ring into my friend's eye, and I have to say, it looks pretty cool.
    Obviously there is still a little ways to go before  we all have glowing eyes, but like I said, it's a start. I plan on making another, thinner PCB and maybe trying to to use 302 leds to cut down on the material of the circuit board. As you can see in the picture above, the assembly is bulky enough that every time the user blinks, it get pushed down the eye, and sometimes even comes out entirely.
    Also it should go without saying that there is some inherent danger in this project. Generally bright lights shining directly into eyeballs, and sharp objects near them are a recipe for disaster. However, it is worth noting that all of the light from the LEDs is shining directly out of the user's eye, so there is little danger of blinding yourself.
    Let me know if you have any thoughts, suggestions, or words of warning!
View all 3 project logs
Rich text editor
Nagy Szabolcs wrote 10/27/2022 at 08:24 point
Just use florescent contact lenses and black light, much better effect without losing your eye.
Chris wrote 10/27/2022 at 12:28 point
Cosmetically similar approach but functionality wise that's all wrong.
I'm scratching my corneas for science, so you don't have to! ™
Reaper-Nam wrote 05/07/2021 at 23:17 point
Hm. I can think of a few design changes that might be worthwhile. Firstly, have you tried using a colored contact for the rear? The type they use for vampires and crap in movies, it should block alot of the light and help protect the eye, they also tend to be stiffer and larger, which should reduce a number of issues. Secondly, maybe try using graphene instead of copper tape, you can get a graphene thermal pad from thermalgrizzly (carbonaut) and trim it to size, alot lighter than copper and less harmful to human anatomy. Thirdly, you could get a nose ring (side wall type) and replace the tip with a batterypack from a vibrating tongue ring, or led earrings to power it, then get an epidermal piercing next to your tear gland so you can route the wires (also recommend using graphene, should be flexible and durable enough for it), which should even more reduce the chances of it rolling up, folding, etc. With those 3, you should have a way more complete product, that admittedly requires the cost of 2 piercings, but its like building a case for a computer serving no purpose other than protecting and isolating the hardware, the end product should also look alot better, as the black contact should hide the wiring (graphene will blend in well). The nose piercing also allows you to turn it off and on easily in an inconspicuous manner. With the bonding of the 2 contact lenses, you should be able to use medical glue (used to seal wounds), it shouldn't react to the contacts and is completely safe to human anatomy. You can also experiment with sealing the leds and graphene strips with it instead of the sandwich method? Admittedly, I dont see much use for the device, but when microcameras get good enough to make it viable to add a camera to the setup and put a tiny bluetooth emitters in the nose ring, it would be a really cool device. Hope this info helps your development, goodluck.
John wrote 04/10/2019 at 21:45 point
you can try adding an antenna to it and power it like a NFC device with a powered coil hidden in a fake glasses frame.
hopefully your not one of those people who can easily get one stuck behind their eyelid.
10-12 years of constantly wearing contacts and that's never happened to me.
Chris wrote 04/11/2019 at 17:50 point
That might be a possibility in the future, but I kinda dig the wires - very cyberpunk imo. And if it ever gets stuck I just need to yank on the wires and it comes right out!
Kevin wrote 04/10/2019 at 20:35 point
I just want one in red so I can do the Terminator for Halloween...
Rene wrote 04/10/2019 at 18:46 point
Hey. Looks like an awesome project (yes it induces also awe for the balls of not caring about your eyes). But how is there not a picture of it being turned on in your eye?
Chris wrote 04/11/2019 at 17:47 point
I'm doing it so you don't have to :)
and good things come to those who wait!
UtilityDave wrote 03/28/2019 at 01:53 point
a normal eye is more oblate toward the nasal and more prolate toward the temple.
a curved open shape might work better?
And as a precaution, try to embed this in something safely rather than sandwiching, corneal abrasion is no joke. there are optical adhesives, but I can't speak to their safety in long term exposure to your eye.
Another concern is the possible UV emission, you've given up all of your protection that close to your eye, and I don't know the spectra emitted by those particular LED's but you don't want cataracts.
This is a cool project! Good luck with it.
Chris wrote 03/28/2019 at 18:22 point
Something that I actually neglected to mention in my log was that I did indeed cut a small wedge out of the PCB. That way when I brought the two ends together into a ring again it was conical. I fiddled with it quite a bit to try to get the right curvature but it's really tricky. Good catch'
I'm not terribly concerned with the sandwiching as it has proven to be a reliable method for such endeavours for other hackers and researchers. I'd be more concerned about putting adhesive/chemicals that close to my eye :)
Sophi Kravitz wrote 03/27/2019 at 18:53 point
@L W look!
Sophi Kravitz wrote 03/27/2019 at 18:51 point
Creeeepy. But neat. I worry that you'll put the LED in backwards-facing and blind yourself.
Dan Maloney wrote 03/25/2019 at 15:45 point
First: Ick, but a cool ick
Second: https://youtu.be/vTZCjCYsytM?t=50
Third: A tiny CCD camera would be cool too - record everything you see.
