• Manual transliteration
    ReVision • 04/09/2019 at 16:26 • 0 comments
    Thought I would try some manual transliteration while waiting on some components, I'll try syncing this with audio/video later, based on my Welsh/British accent.
    All the world's a stage,
    And all the men and women merely players;
    AO L SIL TH ER SIL W ER L D S SIL AE SIL S T EY JH  SIL
    AE N D SIL AO L SIL TH ER SIL M EH N SIL AE N D SIL W IH M EH N SIL M IY AE L IY SIL P L EY Y ER S SIL
    04 15 00 1F 0C 00 24 0C 15 09 1D 00 02 00 1D 1F 0D 13 00
    02 17 09 00 04 15 00 1F 0C 00 16 0B 17 00 02 17 09 00 24 11 16 0B 17 00 16 12 02 15 12 00 1B  15 0D 25 0C 1D 00
  • Phenome generation software
    ReVision • 04/07/2019 at 09:35 • 0 comments
    I plan on learning/using an open source phoneme recognition package called cmusphinx/pocketsphinx.
    https://cmusphinx.github.io/wiki/phonemerecognition/
    Also there are 39 phonemes (plus a silence) so my design will increase the outputs from 32 to 39.
    I have also noticed that these are always sequential so can be represented in 6 bits rather than the previous 32. For practical reasons each character should be represented as 8bit, or 2 hex characters.
    Examples of the decoding taken from the cmusphinx is laid out below, with hex values added.
    HEX    CMUBET   IPA   Example   Translation
    00     SIL      .     silence   ...word-end [ SIL ] word-start...
    01     AA       ɑ     odd       AA D
    02     AE       æ     at        AE T
    03     AH       ʌ     hut       HH AH T
    04     AO       ɔ     ought     AO T
    05     AW       ɑʊ    cow       K AW
    06     AY       ɑɪ    hide      HH AY D
    07     B        b     be        B IY
    08     CH       ʧ     cheese    CH IY Z
    09     D        d     dee       D IY
    0A     DH       ð     thee      DH IY
    0B     EH       ɛ     Ed        EH D
    0C     ER       ɜɹ    hurt      HH ER T
    0D     EY       eɪ    ate       EY T
    0E     F        f     fee       F IY
    0F     G        ɡ     green     G R IY N
    10     HH       h     he        HH IY
    11     IH       i     it        IH T
    12     IY       ɪː    eat       IY T
    13     JH       ʤ     gee       JH IY
    14     K        k     key       K IY
    15     L        l     lee       L IY
    16     M        m     me        M IY
    17     N        n     knee      N IY
    18     NG       ŋ     ping      P IH NG
    19     OW       oʊ    oat       OW T
    1A     OY       ɔɪ    toy       T OY
    1B     P        p     pee       P IY
    1C     R        ɹ     read      R IY D
    1D     S        s     sea       S IY
    1E     SH       ʃ     she       SH IY
    1F     T        t     tea       T IY
    20     TH       θ     theta     TH EY T AH
    21     UH       ʊ     hood      HH UH D
    22     UW       u     two       T UW
    23     V        v     vee       V IY
    24     W        w     we        W IY
    25     Y        j     yield     Y IY L D
    26     Z        z     zee       Z IY
    27     ZH       ʒ     seizure   S IY ZH ER
  • Transliteration protocol ideas
    ReVision • 04/05/2019 at 18:56 • 0 comments
    My concept is to break language in to 4 groups of 8 phonemes. Additional sounds would be created by combining these like you would colours, for example the word 'of' would begin with the 'o' sound, and 'us' would begin with the 'u' sound, but the vowels in the word 'boot' would trigger both the 'o' and 'u''.
    My example of how the channels are broken down.
    12345678
    Soft consonants
    Quiet
    C/S(+ch/sh) F/Ph/Gh/JHThWY**
    Soft consonants
    Loud
    LMNRVXZ*
    Hard consonants
    BC/K/QDGJPT*
    Vowels
    AEIOU***
    *denotes spare channels, which would probably be assigned later, or used as a modifier like an accent.
    The output box would be fed via a serial stream at a suitable speed that could be determined by experiment, but as fast speech is 10 syllables per second, then a sample rate of 50 phonemes per second should be the bare minimum.
    If the signal running as 1 bit per phoneme then each sample would be 32bit uncompressed, with each phoneme type being represented by 2 hexadecimal digits
    in this instance the word 'wigwam' would be
    00001000 00000000 00000000 00000000 #08000000 W
    00000000 00000000 00000000 00100000 #00000020 "I"
    00000000 00000000 00010000 0000000 #00002000 "G"
    00000000 00000000 00000000 10000000 #00000080 "A"
    00000000 01000000 00000000 00000000 #00400000 "M"
    As a scripted file, in the manner of standard subtitle files each line starts as follows...
    hh:mm:ss.mms
    hh is hours
    mm is minutes
    ss is seconds
    mms is milliseconds
    so the above script would be...
    00:00:00.00 #08000000
    00:00:00.10 #00000020
    00:00:00.20 #00002000
    00:00:00.30 #08000000
    00:00:00.40 #00000080
    00:00:00.50 #00400000
    00:00:00.55 #00000000
    the last part being return to silence.
    Possible pattern of contact points.
    Improved pattern of contact points.
    Any thought would be appreciated.
