Designing of PCBs for ESPboy modules
01/31/2022 at 20:14 • 2 commentsTo date, quite a few prototype expansion modules have been developed for ESPboy. There are almost 30 so far. The prototypes are fine-tuned, both the hardware part and the software part. All prototypes are made on breadboards to date. It's time to make the factory PCBs!
For a start, I made three
1. CC1101 for ESPboy Sub1Ghz inspector and ESPboy scanner
2. LORA for ESPboy LORA up to 8km offgrid messenger
3. Weather station for ESPboy weather station :)
Ordered the fabrication on easyeda. After the tests, all circuits and boards will be available for ordering at EasyEda.com, and probably also available for purchase at Tindie.com
Filling up the ESPboy AppStore
01/30/2022 at 14:44 • 0 commentsContinuing to add apps and games from my childhood to the ESPboy AppStore
ZX Spectrum 48K games added:
1. Astromarines corps
2. Bonnie & Clide
3. Boulderdash
4. Chronos
5. Commando6. Cybernoid
7. Dizzy1 extended
8. Flying sharkMore additions are planned for next week.
Stay tuned! -
ESPboy walkie-talkie using UHF/VHF 2watt SA868/818 module
12/29/2021 at 10:21 • 0 commentsESPboy walkie-talkie using UHF/VHF 2watt SA868/818 module
Source code: https://github.com/ESPboy-edu/ESPboy_WalkieTalkie
ESPboy prototype boards
12/29/2021 at 10:12 • 0 comments -
T-REX duino ported for ESPboy
12/07/2021 at 12:02 • 0 commentsThe most famous Dyno in the world ) Thanks to Chrome browser!
Source code of ESPboy fork
https://github.com/ESPboy-edu/ESPboy_t-rex_duinoOriginal code by Alexander Blk for Arduino and OLED 128x64
https://github.com/AlexIII/t-rex-duino -
Doom-nano ported for ESPboy
12/06/2021 at 12:24 • 0 commentsJust ported for fun famous Doom-nano by David Ruiz for the ESPboy
This is not an actual Doom game, just picked some sprites from it (and simplified a lot). The rendering engine is more like a Wolfeistein 3D.
Original code by David Ruiz for Arduino Nano and OLED 128x64
https://github.com/daveruiz/doom-nanoSource code of ESPboy fork
https://github.com/ESPboy-edu/ESPboy_doom-nano -
ESPboy Sub1Ghz frequency scanner
12/05/2021 at 10:22 • 0 commentsScan the radio band in the defined limits 300-348 MHz, 387-464 MHz and 779-928 MHz, as long as the CC1101 chip allows. Select the desired frequency and pitch. Easily determine the frequency of active radio signals around you.
Source code https://github.com/ESPboy-edu/ESPboy_Sub1GhzScanner
ESPboy Smart ice fishing rod tests
11/22/2021 at 20:10 • 0 commentsESPboy module - Smart ice fishing rod tests OK
5 hours of continuous operation at -5C in wind and snow without any signs of degradation or problems
Improved breadboard ESPboy
11/22/2021 at 10:01 • 0 commentsImproved breadboard ESPboy. Just 6 cheap parts overall
ESPboy_ZX48 LinKeFong core and improved sound rendering
10/23/2021 at 15:26 • 0 commentsESPboy ZX48 LinKeFong core and improved sound rendering
ZX spectrum 48K emulator released.
Fast speed and almost ideal beeper sound rendering engine
Here is the code
