1Summary
Assembly steps
- Printing and removing support material
- Fingers assembly
- Thumb assembly
- Inserting the motors on the palm
- Inserting the motor on the thumb
- Fingers and palm assembly
- Casting silicone in the molds
- Gluing the silicone “skin” in the fingers
- Mounting the electronics and electrical components in the palm
- Electric conections
- Assembling the covers
- Upload the firmware
- Start exploring!
Tools
- Micro USB cable
- M3 allen key
- Little flat blade screwdriver
- Phillips (star) screwdriver
- M3 drill bit with driller
- Lime
- Super glue
Bill of materials
- 5 x Micro linear servos motor Actuonix PQ12R
- 1 x Rotary servo motor Tower pro MG90S
- 1 x Arduino/Genuino Nano
- 2 x DFRobot OYMotion SKU:SEN0240 EMG analog sensor or Mioware EMG analog sensor
- 1 x Pololu DV2425F6 Voltage regulator
- 1 x Pololu Switch ON/OFF
- 1 x Grasp PCB board (optional)
- 1 x Tournigy Nano-tech 6000 mAh or other Li-po 7.4 V power supply
- 1 x Li-po battery charger
- 1 x DFRobot 0029-B Pushbutton module
- 10 x M3 allen screws 10 mm long
- 12 x M3 allen screw 16 mm long
- 1 x M3 allen screw 20 mm long
- 4 x M2 blade screw 8 mm long
- 2 x M4 star screw
- 1 x M10 allens screw 30 mm long
- 1 x MG90S servo screw
3D printed parts
- 4 x Finger distal phalanx
- 4 x Finger proximal phalanx
- 4 x Joint
- 1 x Palm
- 1 x Thumb core
- 1 x Thumb distal phalanx
- 1 x Top cover
- 1 x Bottom cover
- 1 x Finger grip mold
- 1 x Thumb grip mold
2Printing
Once you have the downloaded files you can use any SLS or FDM printer to print the parts in PLA, ABS or resin, a tough resin is recommended for their mechanical propierties.
As an example the hand can be printed in a FDM printer (BQ Hepsteros 2) using the following settings:
- Material: PLA 3D850.
- Wall thickness: 1.2 mm.
- Filling percentage : 20 %.
- Filling pattern: Lines.
- Printing temperature: 230 ºC
- Printing speed: 60 mm/s
3Fingers assembly
4Thumb assembly
5Inserting the linear actuators on the palm
6Inserting the linear actuators on the thumb
7Fingers and palm assembly
8Casting the silicone in the molds (wait for 72h)
9Gluing the silicone “skins” on the distal phalanx
10Electronics
