Grasp Bionic Hand
Grasp is a robotic hand designed to to be assembled by a non experienced user and can be useful for different applications.
Grasp is a 6 DOF bionic hand based on the Arduino Nano micro-controller. The main design motivation behind this project is to achieve an affordable prosthetic hand able to do the most important types of grasps for the activities of daily living and could be improved for the DIY community but, can be used for different purposes: robotics, research, education, hobby. The features achieved are close to the best prosthetic hands: 350g, 6.8 N of fingertip force and 72 º/s of finger flexion-extension speed.
This is the last iteration of the project with 6 DOF.
Printed parts on PLA:
1x Palm
1x Bottom cover
1x Top cover
1x Thumb core
1x Thumb distal phalanx
4x Joint
4x Distal Phalanx
 4x Proximal Phalanx
The Covers of the fingers can be made with silicone ore rubber using the molds. At least you will need:
1 x Finger mold1
1 x Finger mold2
1 x Thumb mold1
1 x Thumb mold2
1 x Arduino Nano
5 x Actuonix PQ12R
1x Micro servo MG90S
6V Power supply
10 x M3 allen screws 10 mm long
12 x M3 allen screw 16 mm long
1 x M3 allen screw 20 mm long
4 x M2 blade screw 8 mm long
2 x M4 star screw
1 x M10 allens screw 30 mm long
1 x MG90S servo screw
Grasp Design and Preliminary Testing of an Open-Source, 3D Printable Bionic Hand .pdf
Article also available on engrXiv: https://engrxiv.org/j9kg6/
Adobe Portable Document Format - 1003.42 kB - 08/20/2020 at 17:36
Preview
STEP files.zip
STEP Files of all parts and the assembly
x-zip-compressed - 2.12 MB - 08/20/2020 at 17:35
Download
Grasp_control_3.ino
Basic control of the hand.
ino - 3.06 kB - 04/26/2019 at 23:15
Download
Thumb distal phalanx.STL
Standard Tesselated Geometry - 487.58 kB - 04/14/2019 at 19:27
Download
Finger distal phalanx.STL
Standard Tesselated Geometry - 386.70 kB - 04/14/2019 at 19:27
Download
View all 16 files
View all 4 project logs
  • 1
    Summary
    Assembly steps
    • Printing and removing support material
    • Fingers assembly
    • Thumb assembly
    • Inserting the motors on the palm
    • Inserting the motor on the thumb
    • Fingers and palm assembly
    • Casting silicone in the molds
    • Gluing the silicone “skin” in the fingers
    • Mounting the electronics and electrical components in the palm
    • Electric conections
    • Assembling the covers
    • Upload the firmware
    • Start exploring!
    Tools
    • Micro USB cable
    • M3 allen key
    • Little flat blade screwdriver
    • Phillips (star) screwdriver
    • M3 drill bit with driller
    • Lime
    • Super glue
    Bill of materials
    • 5 x Micro linear servos motor Actuonix PQ12R
    • 1 x Rotary servo motor Tower pro MG90S
    • 1 x Arduino/Genuino Nano
    • 2 x DFRobot OYMotion SKU:SEN0240 EMG analog sensor or Mioware EMG analog sensor
    • 1 x Pololu DV2425F6 Voltage regulator
    • 1 x Pololu Switch ON/OFF
    • 1 x Grasp PCB board (optional)
    • 1 x Tournigy Nano-tech 6000 mAh or other Li-po 7.4 V power supply
    • 1 x Li-po battery charger
    • 1 x DFRobot 0029-B Pushbutton module
    • 10 x M3 allen screws 10 mm long
    • 12 x M3 allen screw 16 mm long
    • 1 x M3 allen screw 20 mm long
    • 4 x M2 blade screw 8 mm long
    • 2 x M4 star screw
    • 1 x M10 allens screw 30 mm long
    • 1 x MG90S servo screw
    3D printed parts
    • 4 x Finger distal phalanx
    • 4 x Finger proximal phalanx
    • 4 x Joint
    • 1 x Palm
    • 1 x Thumb core
    • 1 x Thumb distal phalanx
    • 1 x Top cover
    • 1 x Bottom cover
    • 1 x Finger grip mold
    • 1 x Thumb grip mold
  • 2
    Printing
    Once you have the downloaded files you can use any SLS or FDM printer to print the parts in PLA, ABS or resin, a tough resin is recommended for their mechanical propierties.
    As an example the hand can be printed in a FDM printer (BQ Hepsteros 2) using the following settings:
    • Material: PLA 3D850.
    • Wall thickness: 1.2 mm.
    • Filling percentage : 20 %.
    • Filling pattern: Lines.
    • Printing temperature: 230 ºC
    • Printing speed: 60 mm/s
  • 3
    Fingers assembly
View all 13 instructions
Xavi Cano wrote 11/07/2019 at 17:27 • point
Thank you very much! What a nice time in Bucharest! Amazing competition!
Gabriel Chira wrote 11/06/2019 at 17:26 • point
Awesome documentation and Instructions, this project rocks! \m/
Best of luck with the project, i was the red-haired dude from Saturday in Bucharest!
