The PCB Gerber file for EMG sensor, size 50x26 (mm) Use this for easy soldering and starting point. This design has been utilized for components available on the market.
ALL THE STL FILES NECESSARY TO CREATE THIS PROSTHESIS. Have fun :D And if you successfully made one, please send me an image! If you have any difficulty while printing and building the prosthesis, also send me a message.
This is a .3mf file with all the parts of the elbow module in place. Use this file to guide you through the assembly of the elbow. WARNING: There are some parts that are used several times, but I only put 1 instance of it in the 3mf file to not causing confusion.
This is a .3mf file with all the parts of the wrist module in place. Use this file to guide you through the assembly of the wrist. WARNING: There are some parts that are used several times, but I only put 1 instance of it in the 3mf file to not causing confusion.
The final thesis of this project. I used it as my capstone project at university, and wrote a thorough report for everything I have done, including the design, the literature review, all the schematics and communication protocols, BOM and project management.
Adobe Portable Document Format -
5.99 MB -
09/18/2019 at 17:21
