VAIO Palmtop PC mSATA SSD upgrade
In the quest for upgrades and 'future proofing' I will attempt to squish an mSATA SSD into a Vaio palmtop where nature never intended.
nfmNFM
Public Chat
I have a Sony Vaio VPCP11 palmtop PC in which I have already upgraded the WiFi and Bluetooth, replaced the keyboard with a US version, and installed (a very debloated) Win10.
The next obvious step is to replace the SSD with something more modern simply because I can (Or so I hope...)
The existing SSD is a 256Gb Toshiba THNSNB256GMLJ and is getting a little old these days.
I have run a benchmark on the Vaio, and the SSD maxes out at some relatively low numbers...
Part of this will be the age of the drive, part of it will be due to the VAIO only supporting a PATA interface, hence the flat flex cable from the motherboard to the SSD contains a SATA to PATA converter chip.
I'm hoping the PATA bottleneck doesn't restrict the speed of the new SSD too much, but if the performance gains aren't great with the new SSD, well at least I had fun... :D
This SATA-PATA issue complicates things just a little, as not only do I need to adapt from one connector type (ZIF/LIF on the Toshiba SSD to mPCIe on the new mSATA SSD) to another, but I also have to include a SATA to PATA converter chip too.
Toshiba SSD Benchmark
Benchmark of existing Toshiba SSD
Here's the benchmark of the existing SSD shown above. Not too impressive by any stretch of the imagination...
Lets crack open the machine to see what we are up against.
Vaio Palmtop Opened Up
Vaio VCPC11 Palmtop Opened Up
It's pretty tight inside as you would expect.
The new WiFi/Bluetooth card is the green PCB to the right.
The motherboard is the blue PCB to center right and the green PCB to center left is a daughterboard that contains the WWAN card, Bluetooth card and breaks out to the USB/VGA/Ethernet ports on the far left top.
The small green PCB to the far left is the SATA to PATA adapter, and the Toshiba SSD is sitting underneath, between the SATA-PATA and daughter PCB's and keyboard located on the other side of the Vaio.
Extreme Disembowelment!
OMG, what have I done!?
Here's the parts removed out of the way.
Clockwise from top left.
SSD carrier frame, Toshiba SSD, Daughterboard, SATA-PATA converter/flex interconnect.
I found that the SSD carrier frame can be left out along with the SSD with no ill effect, this machine came with a few HDD/SSD options so it seems to have been designed so that nothing else in the machine is dependent on that frame. This is good as it enables me to clear out as much space inside as I can.
Time to prune the hedge.
Away with thee, useless accrument!
Here's the other side of the daughterboard. I have removed the WWAN card as I won't be using it and it'll leave some space for the new cable to run through if needed. Also, less parts = less power drain on the battery.
The small white connector near the middle was for the Bluetooth module. This was also removes and the new WiFi card has Bluetooth built in anyway (with newer drivers etc).
Also, before you ask, I did try the mSATA SSD in that mPCIe slot. No go at all. It doesn't have the required SATA connections, which is a bummer but not surprising seeing as this chipset only supports PATA.
mSATA SSD Fitment Test
We might be onto something here....
After measuring, test fitting, remeasuring, re-test fitting, etc, etc, I think this is where the new SSD will end up fitting.
It has more than enough height to fit in there even with a mPCIe connector, and it slots in next to the daughterboard perfectly.
Test Fit of eBay SATA-PATA Adapter
Boooo, things are never so easy!
I purchased this flat-flex to mPCIe PATA-SATA adapter from eBay for a few dollars, but it just doesn't fit.
Unfortunately it is large enough that I can't even take a bit of a sneaky trim of the PCB either. It's also too tall to fit under the daughterboard too (That would have been too easy... :D )
I think I might have to fire up Diptrace to design up a custom PCB.
Having a think about it, if I were to make a 1mm thick PCB that is no wider than the mPCIe connector and if I put the flat-flex connector on the right-hand side, I reckon it'll fit just nice.
I have a decent (Hakko FM-206) rework station too, so salvaging and reusing that chip under the 'QC Passed' sticker and maybe even the mPCIe slot shouldn't be too hard.
Flex PCB Mockup
My hopes and dreams...
Here is where we sit now.
This is my idea mocked up roughly in place. I plan to have a flex PCB from the motherboard on the right, running over to the (to be built) SATA-PATA PCB and hooking into a flat-flex connector that will be on the right side of said PCB.
Then the new SSD will...
  • Small update is small
    NFM06/14/2019 at 01:08 0 comments
    Just a quick update of no real importance.
    I'm working on the PCB layout and still figuring out how to fit it all in.
    I found a nice socket and screwless retaining clip for the SSD, but there isn't quite enough space for it. :(
    I'll have to do a little more measuring to nail down the fitment, it'll be really close, but I don't think it's completely impossible.
    Tha't pretty much all for now, finished PCB layout to come soon.
  • PATA to SATA Schematic
    NFM05/26/2019 at 05:02 0 comments
    I've been recently working on the schematic for the PATA to SATA adapter. (PATA on the left, SATA on the right).
    It seems to be all sorted now, pending the small corrections I inevitably find later (hopefully before I spin the boards...)
    I went a bit wild on the decoupling, just because, and at the bottom center-ish you'll see J3, this will be a solder jumper that can enable spread spectrum to reduce EMI if it doesn't affect performance too much (Benchmarks to see what happens later).
    I also made a small revision to the flat-flex cable, I just moved that rogue connection to pin 40 up to pin 37 where it matches up as the indicator activity led as I thought.
    I also tweaked the equal length traces to neaten them up a little too.
  • Dirty Schematics.
    NFM05/22/2019 at 01:49 0 comments
    Here's the latest schematic. As dirty and messy as it is.....
    Motherboard connector is on the right, ZIF pinout on the left.
    Pin 39 from the motherboard doesn't seem to have an equivalent pin in a HDD ZIF socket, it goes to pin labelled 'T1' (pin 34) on the Marvell 88SA8040 SATA Bridge chip.
    I'm not sure what it does exactly (I think it's the 'device active' signal, to flash the HDD activity LED), so if anyone knows, let me know!
    I have passed this pin through to pin 40 on the ZIF connector, it is used for Master/Slave select on the ZIF socket so it has no use here, so it will be fine to repurpose that pin.
    It seems data is a bit hard to find on the Marvell 88SA8040 chip, beyond a basic pinout.
    If anyone has more info, I'd be very grateful for anything that can be offered.
    I've measured the voltage coming from the motherboard too, which is at 3.3V, so that's good. I only need one Vreg to give me a 1.8V rail.
    Next step is to start designing the SSD daughter-board.
    I think I'll forgo using the Marvell 88SA8040 chip due to it's lack of data etc, and instead use the more common JMicron JM20330.
    The benefit is a data sheet and easier availability as it can be lifted from many ebay adapters.
  • PCB time!
    NFM05/21/2019 at 15:55 0 comments
    PCB is all laid out! I got it just under 2 square inches which is nice.
    I beeped out the connector on the Vaio flex cable and wired my flex adapter so match on the motherboard end, and match a 40-pin ZIF socket on the other.
    All the connections are length matched to within +/- 0.1mm too for fun and signal integrity.
  • Matching plugs match.
    NFM05/19/2019 at 04:18 0 comments
    Winner winner, chicken dinner.
    I got the plug from Digikey the other day, and it fits goodly so.
    It's a little lower than the one Sony used (They have a few height variances) and doesn't have the metal inserts, but it fits perfectly, so no problems I think.
    Next step is to make footprints and start laying out the PCB.
  • A match made in heaven?
    NFM05/05/2019 at 05:39 0 comments
    After a bit of a peruse of Digikey, it looks like I might have a match!
    I took some measurements (0.4mm pitch etc) and made a few assumptions as to brands, I assumed that Sony would use a Japanese brand for their Japanese product, so looked primarily at Hirose and Panasonic offerings (I didn't preclude other brands, though, just in case).
    It turns out that Panasonic parts AXK740147G‎ (for the socket) and AXK840145WG‎  (for the plug) are looking preeettyyy close to what I'm after.
    https://www.digikey.com/product-detail/en/AXK740147G/255-2534-1-ND/1986697/?itemSeq=291802877
    https://www.digikey.com/product-detail/en/AXK840145WG/255-2527-1-ND/1986690/?itemSeq=291802878
    Next step, add these parts to an order and see if the plug fits the socket on the motherboard.
  • Flat-flex plug and socket
    NFM05/04/2019 at 08:30 0 comments
    I cracked out the microscope and macro lens and took a few photos of the connector for the existing flat flex to the motherboard.
    Next is to try to track one of these down... Any ideas? :)
View all 7 project logs
Rodrigo MaLó wrote 07/16/2021 at 20:24 point
So, you make it?
What if you make more room printing a cap with more room for all the ssd stuff?
John Irving wrote 07/28/2020 at 00:47 point
For example, buy that sony converter cable I previously mentioned and then fit your mSATA drive to this mSATA to uSATA adaptor (https://www.aliexpress.com/item/4000046088794.html) and just plug it in....?
John Irving wrote 07/28/2020 at 00:44 point
Latest addition: That cable I mentioned is clearly visible in a photo from one of the two sellers on aliexpress.com.  It looks like it converts to uSATA and there are of course drives around that have uSATA interfaces, but most if not all are used.  I'm now wondering if this Sony cable plus a uSATA to mSATA converter would be possible?
John Irving wrote 07/28/2020 at 00:36 point
Incidentally, the earlier VGN model converter cable being mentioned in this thread by another poster is probably part number IFX-536 1-878-429-11.  There are two sellers on www.aliexpress,com that have stocks of this item for about US$30.  I know this has the correct plug on one end for the motherboard, but I was unsure what this cable/chip combination converted to.  If it's mSATA or 40-pin ZIF then it might be job done.
John Irving wrote 07/28/2020 at 00:31 point
I had similar thoughts to your own and in fact ended up buying an mSATA drive and exactly the same mSATA to 40-pin ZIF converter!
I now realise this combination of components isn't going to fly.
Having had another look around at various converter boards, etc. - I wonder if you have considered this combination:
1. A 1.8inch LIF to 2.5inch SATA 24Pin ZIF to 22Pin SATA Converter Adapter Card, found here: https://www.ebay.co.uk/itm/1-8inch-LIF-to-2-5inch-SATA-24Pin-ZIF-to-22Pin-SATA-Converter-Adapter-Card/112582719680
2. A 2.5" SATA to mSATA converter such as this: https://www.ebay.co.uk/itm/Mini-Pcie-mSATA-SSD-to-2-5-SATA-Adapter-Converter-Card-Module-Blue-Green-Boar-/202065680938 or in its alternative form factor: https://www.ebay.co.uk/itm/Black-Mini-Pcie-PCI-E-mSATA-SSD-to-2-5-SATA3-SATA-Adapter-Card-BSG/122993129694
Leave the Sony PATA to SATA converter board in place.
Since there's no actual chip conversion taking place on boards 1 and 2 (i.e. they are bi-directional boards), would it not be possible to just trace the wiring 1 for 1 between the 24-pin LIF socket and the mSATA socket with the two boards connected together?  Then you're down to physically cutting the LIF/ZIF connector and a little bit of surrounding board off item 1, and the mSATA connector (and a little bit of surrounding board) off item 2 and wiring them together correctly, soldering directly between the pins/pads on the back of each connector to get the correct pin for pin conversion.
I can see a few components on both boards - mostly passives and a voltage regulator IC in each case.  Since both boards are "2.5" SATA IN" then these ICs both presumably step down (??) SATA supply voltage to be what's required for 24-pin LIF/ZIF and mSATA drives respectively.  In this respect, the boards are not bi-directional.  All that's needed to replace them however is a 24-pin LIF/ZIF voltage to mSATA voltage converter between the relevant pins.  I assume if you have a spare SATA cable on a PC somewhere you could connect in each converter board in turn and work out what the outputs of these two voltage converters is.  If they're both the same, then the wiring is 1 to 1 for the +ve power supply too - otherwise a new voltage converter is required (LIF/ZIF to mSATA levels) and worst case this might need to be a step-up circuit, but the voltage and current specification will be pretty modest.
Anyway, just my thoughts on the matter.
x86 FanBoy wrote 04/27/2019 at 17:17 point
I might be missing something (like you not having the cable), but the model that included a 1.8" HDD rather than SSD used a cable that would plug directly into your adapter board, and is what I'm currently using in my Vaio P. I have a first gen (No touchpad) and am not sure if they used the same HDD's in that model as yours, but if you could find a cable that may save you some trouble. I just have my SSD mounted 90 degrees to where yours was positioned. (I like your positioning more though, as it allows for much more room internally for other modifications.
NFM wrote 04/27/2019 at 17:25 point
Yeah this is true, but I've found that finding spare parts for these machines is really hard....
I'm not sure if the earlier models have the same ribbon cables as mine, I'd need to compare to see what is usable in my machine.
I'd love to find a broken machine to tear apart. that would be perfect.
x86 FanBoy wrote 04/29/2019 at 18:47 point
I found the same, I always keep a lookout for broken units going up online. In the end, I've bought one that was in pretty good condition, and when mine completely wears out I'll start using the new one and relegate mine to spares (That is if I can't fabricate new parts for it, your projects have me rather interested. Ideally I'd hook up the keyboard, mouse, and display to adapter boards that let you connect your own motherboard of choice to is, as System-On-Module's are starting to outpace the original, but haven't had the time to work on a vanity project like this, not for a fair while)
Richard Hogben wrote 04/22/2019 at 14:59 point
Do you know what year this VAIO is from?
NFM wrote 04/22/2019 at 15:15 point
It was originally released mid 2010.
