Hackaday.io Hackaday.io
Sign up Log in
Nano Z30 a Numbers Only Enigma Machine Simulator
A minimalist 130x74mm Numbers Only Enigma Z30 Machine Simulator using an ATMega 328 powered Arduino Nano and a custom PCB
arduino-enigmaArduino Enigma
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.6k views
11 comments
21 followers
  • Description
  • Details
  • Files 0
  • Components 14
    • View all
  • Logs 11
    • View all
  • Instructions 0
  • Discussion 11
  • Hackaday Prize 2019
View Gallery
2.6k
11
21
21
Team (1)
  • arduino-enigmaArduino Enigma
Join this project's team
  • Enigma Simulator Blog
  • Enigma Z30 Description (cryptomuseum)
  • Source code at GitLab.com
  • Operating Instructions
ongoing project
2019hackadayprize
This project is submitted for
This project was created on 05/22/2019 and last updated 5 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
While waiting for parts for the bigger Mega-Enigma project project, I decided to make a another simulator. The Enigma Z30 is a strange machine that uses rotors to encrypt only the numbers 0 through 9
One thing led to another and in 3 hours, the initial version of the board was routed.
Components
  • 1 × Enigma Z30 PCB https://oshpark.com/profiles/ArduinoEnigma
  • 1 × Arduino Nano
  • 4 × 0.56 inch RED 7 SEGMENT LED DISPLAY COMMON CATHODE.. Either 5161AS or 5611AH https://www.ebay.com/sch/i.html?_nkw=5161as
  • 10 × 5mm Straw Hat LED (YELLOW) https://www.ebay.com/sch/i.html?_nkw=straw+hat+5mm+yellow+led
  • 18 × 6mm x 6mm x 5mm Momentary Tactile Pushbuttons (BLACK) For 0..9 keys and Rotors
View all 14 components
Project Logs
Collapse
  • The whole family
    Arduino Enigma • 05/25/2020 at 22:55 • 0 comments
    And finally, here is a picture of completed units:
    Enigma Uno:
    https://www.tindie.com/products/arduinoenigma/arduino-enigma-i-m3-m4-machine-simulator-w-case/
    NanoEnigma:
    https://www.ebay.com/itm/114230592101
    PicoEnigma:
    https://www.ebay.com/itm/114219267074
    https://www.tindie.com/products/arduinoenigma/picoenigma-a-universal-enigma-machine-simulator/
  • Putting batteries inside the enclosure
    Arduino Enigma • 01/14/2020 at 05:18 • 0 comments
    To put batteries inside a laser cut enclosure, one has to think in 3D using 2D:
    The pictures in this article will show how:
    https://arduinoenigma.blogspot.com/2020/01/how-to-put-battery-compartment-inside.html
    And now that there is a built in battery compartment, then the question of how long will it run on batteries becomes more important.
    The following article shows a method of measuring run-time by writing timing checkpoints to EEPROM, no external components needed.
    https://arduinoenigma.blogspot.com/2020/01/measuring-battery-run-time-by-writing.html
  • The current state of the simulators
    Arduino Enigma • 10/22/2019 at 04:50 • 0 comments
    I always wanted an Enigma-E...
    Editing of UKWD pairs has been added to MegaEnigma
    https://hackaday.io/project/165559-at-mega-enigma-a-2560-pro-mini-enigma-simulator/log/170163-added-menu-to-edit-ukwd
  • Lots of Progress
    Arduino Enigma • 09/24/2019 at 04:21 • 0 comments
    The universal enigma engine seems to be working correctly
    Here are a couple of posts with the current project status:
    https://www.instagram.com/p/B2dJO-4n6Dr/
    https://www.instagram.com/p/B2HatohnKy1/
  • The State of Both Machines
    Arduino Enigma • 07/28/2019 at 17:04 • 0 comments
    Current pictures of the machines:
  • Started Soldering Both Machines
    Arduino Enigma • 06/07/2019 at 11:05 • 0 comments
    Started to solder both enigmas.
    What's wrong with this picture?
    The answer and more pictures here:
    https://hackaday.io/project/165559-at-mega-enigma-a-2560-pro-mini-enigma-simulator/log/164379-arduinos-and-keyboards-soldered
  • The boards are here!
    Arduino Enigma • 06/05/2019 at 10:40 • 0 comments
    Head over to the Mega Enigma Simulator project to see them:
    https://hackaday.io/project/165559-at-mega-enigma-a-2560-pro-mini-enigma-simulator/log/164310-the-boards-have-arrived
  • LED and Keyboard Pin Assignment Completed
    Arduino Enigma • 05/25/2019 at 17:09 • 0 comments
    Here is the pin assignment for the Z30. Fundamentally it is the same circuit in the Mega Enigma, just smaller.
    To understand how this will be illuminated and read, see the following log on the Mega Enigma project page:
    https://hackaday.io/project/165559-at-mega-enigma-a-2560-pro-mini-enigma-simulator/log/163886-led-and-keyboard-pin-assignment-completed
  • The importance of double checking, part 2
    Arduino Enigma • 05/24/2019 at 05:13 • 0 comments
    Here we go again:
    Here is an almost finished design, all it needs it a little tweaking of the bottom silkscreen. Time to add a USB label indicating which way the Arduino Nano is supposed to go.
    Uh Oh...
    The footprint for the Nano has been placed with the USB connector facing towards the LED displays. While this design will technically work, the USB port is concealed.
    Time for a quick re-design:
    Now the USB connector is facing left. Notice the location of the VIN pin, fed from the power switch. The cost of this redesign was two more horizontal traces in the front to get power to the right location now that is away from the power switch.
    Time to check all the connections carefully.
    Arduino Enigma • 05/22/2019 at 00:38 • 0 comments
    Witness the importance of double checking wiring. The menu key (above the 0, is wired to the same select/return line combination as the 0 key (bottom of image). Luckily, another return line passes by and is just a matter of switching the bottom of the pushbutton to a different return line.
    By simply connecting the bottom of the key to another return line, the menu key now has a unique select/return line combination.
    Since these circuits are wired without using a schematic, very careful checking is needed at the end to make sure everything is wired correctly.
View all 11 project logs
Log In/Sign up to comment
Sign up with Github
OR
Rik Moore wrote 06/13/2022 at 12:36 • point
Fantastic thing - and well have to say I've built my own version of this.  Many thanks for this.
Arduino Enigma wrote 06/15/2022 at 04:59 • point
Great to hear. Any pictures of your project?
Rik Moore wrote 06/16/2022 at 07:14 • point
Well as it's basically just taking what you did - the pcb files and working through your component list and code, so it's just yours.  Although I went down the 3D print route for the enclosure - which was fun as i've never designed an enclosure from scratch before.  Had to learn all kind of interesting design skills like how to do hinges.  My aim with the Z30 I'm building is to deploy it as part of a geocaching field puzzle.
As to pictures of my unit well you can see one here:
https://www.tsiolkovsky-creations.co.uk/things/z30-01.jpg
As you can see I went for a blue rather black PCB and the mode key is black, as that was all I had on hand at the time.
As I also built an Kim UNO I next intend to spend the afternoon converting that into a Z30 in line with your code too.. That should be a lot of fun as well.
Arduino Enigma wrote 06/19/2022 at 17:32 • point
It's a very good looking build. I always enjoy seeing motivated people replicate these projects.
On a separate note, I do not know why this project is not getting any love:
https://hackaday.io/project/168713-ciphersaber-a-simple-rc4-cipher-for-arduino
Arduino Enigma wrote 06/19/2022 at 17:33 • point
And links in comments are broken, tried plain links, html and markdown, nothing works.
Tom Nardi wrote 06/04/2019 at 21:45 • point
Fascinating, I'd never even heard of the Z30 before this. Seems like a great "on ramp" for getting into Enigma simulators.
Arduino Enigma wrote 06/05/2019 at 10:43 • point
It is an interesting little machine, it grows on you. I have written a Z30 simulator in 6502 assembly for the KIM Uno based on the description and wiring found on Wik Anders article. This was part of the #1KbChallenge and #RetroChallenge2017
Arduino Enigma wrote 06/19/2022 at 17:34 • point
Links in comments do not seem to work anymore. Tried plain link, html and markdown. Nothing works.
Arduino Enigma wrote 05/23/2019 at 23:04 • point
The 2019 Competition entries will all be listed on @Tindie
Once the parts for the Enigma Simulators are ordered, a batch of Sinclair Kits will also be made available.
At the beginning of the year there were no plans to make any new enigma simulators, but it looks like we are going to have three different ones available soon. Happy.
@Oscarv
Oscarv wrote 05/23/2019 at 10:32 • point
Spectacular! Will you make them as a kit, or should we order the PCBs ourselves?
The 2018 Hackaday Prize
A most stylish wearable music synthesizer! A real stylus based monophonic music synthesizer built into a giant trucker belt buckle!
Project Owner Contributor
Stylish!
tina-belmontTina Belmont
A register level TMS0805 CPU emulator on an Arduino Nano runs the original 320 instruction calculator program. A custom PCB houses it all.
Sinclair Scientific Calculator Emulator
The Redox project is an open-source, QMK (Quantum Mechanical Keyboard Firmware) powered, ergonomic split mechanical keyboard.
Redox keyboard
mattia-dal-benMattia Dal Ben
An emulation station and media streaming device inside a GameCube case
Nintemu NUCube
jamieJamie
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Nano Z30 a Numbers Only Enigma Machine Simulator", please tell us the reason.
Send message
Remove Member
