Future Goals (20190808)
08/09/2019 at 00:10 • 0 commentsThe next revision of this project will focus on the following points.
- I will use a regular polyhedron as a design point, likely a tetrahedron (4 sided die).
- This will simplify the side design and the jig design.
Initially this project was designed to compete in the beautiful hardware competition, but since the contest is coming to a close next week I will not be able to redesign and have everything manufactured in time. I will still keep this project in mind and will post again once it has made noticeable progress.
Assembly Cones of Shame
08/09/2019 at 00:03 • 0 commentsThe reason I was using the helping hand to solder the boards together was because I was able to make a jig to help me solder the boards together. This has made it apparent that I need to review my 3 dimensional geometry.
Failure to Launch
08/08/2019 at 23:56 • 0 commentsI was unable to correctly do the 3D geometry when designing the PCB. Attempts to solder and assemble the sculpture lead to over heating the castellated edges. The de-laminated pads lead to throwing away the design. It was a critical failure in the project.
First Batch of Boards
08/06/2019 at 00:45 • 0 commentsI got a hold of 60 pcbs from PCBway, 30 with plated edges and 30 with castellated holes. I did a quick test of one of the panels and it worked. I am working on a 3D printed jig to help be assemble the final shape. I am using Sn60Pb40 solder for the components and I plan to use SAC solder as the "welds" between the boards.
