Add Wireless charging and planning to use BT 5.1
07/01/2019 at 07:21 • 0 commentsI changed the casing, and upon checking its dimensions, a wireless charding modul;e and its coil would still fit. Also planning to add BT 5.1 for direction and altitude fineding capability.
We Lounched an IndieGoGo campaign
06/30/2019 at 01:21 • 0 commentshelp us succed with this project. https://www.indiegogo.com/projects/booze/x/22037222#/ need you backing, thank you
Added 3D Models
06/29/2019 at 02:45 • 0 commentsI've added 3d models so that I can check if the components perfectly fit inside the casing
PCB Dimesions changed and Micro USB port taken out
06/29/2019 at 00:42 • 0 commentsSInce the casing was changed, I also need to change the pcb size and layout, its like redoing the whole project. But the effort is worth it. Also chamge the number of exposed I/O pins from 10 to 13 becosue the OLED Screen needs some 4 extra pins pehap I alsio want to take out the microusb B port in favor of the female dupont pins beacuse of its low profile. Micro USB will be external beause I will provide a custom adaptor.
Changed Booze Casing and added Oled display
06/29/2019 at 00:36 • 0 commentsI have changed the casing to 43mm x 20mm x 10mm from the previous 40mm x 17mm x 10mm to give way for the 0.5" Oled display which has a board dimension of 17.8mm x 15.2mm x 3 mm. All materials to used are perfect fit for the new casing to use.
Reduced Battery Capacity Due to Size
06/27/2019 at 10:00 • 0 commentsI will be reducing the battery capacity to 60mAH from 75mAH because or the size. The 60mAH battery with dimensions 3mmx10mmx25mm will allow more components to be squeezed into the pcb.
IO Pads added
06/26/2019 at 00:43 • 2 comments10 IO Pads added at the back see newly uploaded picture.
Booze
06/24/2019 at 17:49 • 0 commentsProject was restored after being accidentally deleted.
booze
