Inspiration for track shocks
JPEG Image -
11.23 kB -
07/02/2019 at 00:50
Preview
Mock up of track mounts. This went through 3 changes before i was happy. Now i cut my first aluminum pieces. Jigsaw and drill press. 1/4" aluminum sheet i had laying around. Should have enough to do other side and base plate of robot.
JPEG Image -
3.67 MB -
07/02/2019 at 00:41
Preview
5 pack of track pieces. for printing i combined 5 of them. I can print about 30 on my ender 3. But i typically print 20 at a time. In PLA
Portable Network Graphics (PNG) -
96.22 kB -
06/25/2019 at 01:56
Preview
track assembly test 2. Modified the brackets and moved the wheels around for better clearance. The blue squares are there so i can print to size A paper and align front and back pieces together. then i can glue to aluminum and cut out the shape with wheel alignment.
338.99 kB -
06/25/2019 at 01:50
Preview
Lower Track Assembly. Spring loaded wheels. Uses standard skateboard bearings
85.79 kB -
06/25/2019 at 01:47
Preview
Drawing layout of track bracket. Blue squares are used for alignment when printing. part is bigger then Size A paper. so this is what i did to help tape both pieces together correctly.
27.95 kB -
06/25/2019 at 01:45
Preview
SerialStepperController.ino
Serial communication code for arduino mega and RAMPS board. I had this hardware laying around. Code is setup for a serial control. Send < x,y > can be -1000 to 1000 steps per second. using 0.9 degree step motor. X is my left and y is my right motor. May modify for 3 more steppers later. as ramps can handle 5 steppers
ino -
6.46 kB -
06/25/2019 at 01:39
Download
test mockup of track assembly
566.78 kB -
06/25/2019 at 01:39
Preview
