Battery cases - etc
03/10/2021 at 00:02 • 0 commentsPurchased 2 lipo batteries for this and printed a case to hold them under the main plate.
Also ordered 2 more aluminum sheets cut to size. With standoffs. That way i can put all electronics on the current base then another sheet above that to mount camera/sensors etc. Extra plate just in case i want 3 levels. Already super heav,y so not sure.
Cleaned out the garage and made storage shelfs. That is where the project is living right now. Life got busy last two years. and i've done almost nothing during pandemic :( Time to get back to this project.
See my other project, working on smaller robot. I wanted to build a large controller for this one. So my small robot gets a small controller to see how that goes first.
Then i can spend a lot for my tank controller. need a pi, big joysticks, touch screen. Going to have to cram into the largest box print size my printer can handle. 220x220mm ...going to be a tight fit. Maybe build 3 parts and glue together or snap fit together?
Oh yah i also printed a case for the motor controller. With 2 small fans for cooling. You can see in back left of image.
Need larger standoffs. motor controller case is a little bigger then 1" and wont fit under the plate. So i need 1.25" ones if i can find them.
Project Update - Jetson Nano case
08/26/2020 at 21:45 • 0 commentsOkay it's been awhile since I've put anything on here. 2020 has been a strange year.
Just wanted to add a quick update. I tried to design and print a 3D case for the jetson and it did not fit. instead of trial and error day after day i found a Jetson Nano 3D case with vesa mounts. This gives me what i need a case with mounts to screw into the tank case. See images.
Also i mounted both batters to the bottom of the chassis.
Added wifi/Bluetooth module to jetson nano
Plans to build two levels on top of the base of the chassis. so top down, PTZ camera plate, Sensor plate (ultrasonic, maybe lidar), power and control plate (the chassis plate)
I've seen other robots designed this way with levels for circuits and didn't want to follow it as it seems messy, but the more i think about it i guess it makes sense to do. So i need to cut out two more plates of metal so i can have room for everything.
Case found on thingiverse here https://www.thingiverse.com/thing:4082134 Thanks to whoever you are. They just fit together on my Ender 3 and at 0.3 print height it only took 4-5 hours
Chassis Assembled - Kind of
12/02/2019 at 08:06 • 0 commentsSo i got my parts in a couple weeks back. assembled them and needed something to hold them together. So i put a plate together and mounted them up. So far so good. A couple holes were slightly off. ill just oversize the plate holes and it should be fine. but here it is assembled. Need to get the motor controller mounted somewhere and start playing with the drive system. Make sure nothing binds up and it can turn smoothly etc...
Track brackets came in today!
10/09/2019 at 23:19 • 0 commentsyay, so excited today!
Just recieved my tank track brackets from my friend. Had them laser cut. They came out so nice.
Cant wait to get home and assemble these with the tracks.
Wheel brackets printed
07/18/2019 at 03:13 • 0 commentsprinted one half of the wheels brackets. Need to print the second set.
These parts are ambidextrous so I only have to print the same piece for both sides. For the wheel holders and the suspension bracket that holds them.
Then I press fit in all the bearings into the free wheels. Hammer bench vise and a perfect sized air line quick connect to hammer them in place. The air quick connect was perfect size for the outer part of the bearings. Wish I had a press.
Second track pieces
07/13/2019 at 08:24 • 0 commentsFinished printing and assembling the second set of tracks. only had to print 60 because i had some left over when i printed 80 the first time. about 60-70 per side.
Because i undersized the holes i had to drill each side out and i tapped the inside holes to make it easier to screw in the machine screws. plastic self tapping may be easier? but i had 4x40 1" screws already to use.
Printing my wheels for the second track
07/13/2019 at 07:17 • 0 commentsPrinting my wheels for the second track set. Another 5 hours in. Finally opened my second roll of PLA. About $20 in on printing this thing. Need to print the wheel brackets and the drive wheel needs a redesign for both tracks.
Printing out second set of track pieces
07/05/2019 at 08:19 • 0 commentsOkay back to printing.
Probably wont see anything else for awhile as i print out the second track. Going to take a couple days to get all this out.
Jetson Nano is here!
06/27/2019 at 17:40 • 0 commentsJetson Nano came in last night. Only had time to install the OS image on SD card and open the BOX. Looking into installing ROS on the nano now. Should be fun this weekend.
