DIY Scintillation Detector
Not your granddad's Geiger Counter
Public Chat
Frustrated by the very high price of commercial detectors, I've designed a PCB for Jim Williams' High Voltage, Low Noise power supply, a Voltage Divider for a Hamamatsu R3998-2 Photomultiplier and a housing for a detector made from said PMT and a 2 Inch Sodium Iodide scintillator.
What you do with the output of the detector is, for now, your business. You could plug it in a commercial MCA, an oscilloscope, a pulse counter, whatever. I'm currently working on a DIY Multi-Channel Analyzer for Gamma Spectroscopy, but that part is considerably more complex than what's already here.
All files are available - Schematics, Gerbers, Boms and even a .step file for a 3D Printed enclosure.
Feel free to critique and comment. I'd love feedback.
The power supply is designed by the late and great Jim Williams form Linear Technologies and is considerably better than what Hamamatsu or other photonics manufacturers have to offer.
PMT Socket.pdf
Schematics for the Voltage Divider board.
Adobe Portable Document Format - 77.32 kB - 08/29/2019 at 10:52
Preview
PMT Socket.zip
Updated PCB Gerbers for the PMT Divider board.
Zip Archive - 13.70 kB - 08/29/2019 at 10:50
Download
HVPSU_V2.zip
Updated PCB Gerbers for the HV supply
Zip Archive - 33.13 kB - 08/29/2019 at 10:50
Download
Detector Housing.STEP
.STEP File for the 3 components of the housing. Print away. All parts fit together with an interference fit. Should be secured with some duct tape
step - 69.88 kB - 07/11/2019 at 06:40
Download
HVPSU.pdf
Schematic for the High Voltage Power Supply. Updated Version
application/pdf - 220.12 kB - 07/11/2019 at 06:34
Preview
View all 7 files
  • 1 × Scintillator Crystal 2 Inch Thalium-doped Sodium Iodide Crystal
  • 1 × Hamamatsu R3998-02 Photomultiplier Tube PMT made for High Energy Physics and Scintillation Counting
  • 1 × High Voltage Power-Supply Jim Williams' design for a -1KV, low noise PSU
  • 1 × Voltage divider for PMT Necessary to bias the dynodes to the required potential for the photoelectric magic to happen
  • 1 × Housing for the detector Needs to be light-tight
  • Resolution
    Alex Lungu08/29/2019 at 11:04 0 comments
    Well, this is both the resolution for the project and the measurement of the energy resolution (pun intended?).
    I've taken some rough measurements, just so as to see the general ballpark i'm in regarding energy resolution.
    For 226 Radium from a "choob" (Tube) meant for Radars, i got about 9.4 % FWHM (Full Width at Half Maximum) which is pretty close to the 8% a regular Sodium Iodide crystal has. Granted, they're usually spec'd for 8% FWHM 662keV, but i've still got some noise in the cables and too much digital gain. Amplifier PCBs are here, but i'm still waiting for parts.
    What i was expecting
    What I got
    There's a lot of background and XRF, but the peaks are where they should be and, with some copper shielding and a lead castle I'll get better results.
    For now, I'm quite pleased with the result.
  • HV PSU Completed
    Alex Lungu07/24/2019 at 13:39 0 comments
    After waiting for the right LT1534-1 ICs to arrive, today I finally completed the HV supply.
    I've powered them up and tested them. The gods were kind because everything worked perfectly from the first try.
    The 2 boards, assembled and tested.
    Thermal image. Hottest component under load is the Controller IC, clocking in at 40 Degrees Celsius.
    Powering the detector with the brand new supply.
    The 2 finished supplies.
    Big Orandge Drop capacitors. I tried 2 different configurations of the output Pi RC filter. Both seemed to perform equally good.
    Output noise measured in a 100MHz bandwith is around 1.5-2 mV. Didn't take a photo of the measurement setup because i was juggling 3 probes, decoupling caps and knobs.
  • Finished Detector, waiting for PSU
    Alex Lungu07/16/2019 at 10:13 0 comments
    So, the detector itself is completed. Untill i get the materials for a complete aluminium housing, I'll stick to using the 3D printed one i've already got.
    The detector itself feels quite nice in the hand (it's pretty darn comfy, if I do say so myself) and nicely weighted and balanced. An aluminium housing would only improve the overall look and feel.
    I've finally gotten all the parts from Digikey, including the Amphenol BNCs on the back.
    One is for the negative high voltage and the other one is for the output signal.
    It's a tight squeeze, but 2 BNC cables DO fit at the same time.
    Sorry about the potato quality photo, but my phone's camera is really crap.
  • Pulses
    Alex Lungu07/11/2019 at 13:59 0 comments
    So i finished 3D printing the housing, my parts aren't here yet, but I cobbled together a High Voltage PSU and tested the detector. And it works just as expected: great :D
    Just background radiation picked up by the crystal. It picks up somewhere around 30 events per second, my Geiger Counter picks one up every 5 seconds or so (A Gamma Scout w Alert). Goes to show how much more sensitive a scintilation counter is.
    Didn't get the BNC's either, so i drilled a couple of holes in the back cap and ran the wires through.
    And this is my workbench. The pink block is a Wima filter capacitor filtering the -1000V supply for the PMT
  • Hooray for Altium
    Alex Lungu07/11/2019 at 07:19 0 comments
    Took a few days, but i've finally finished the PCB design for all the components of the detector.
    I know i'm posting everything in one day, but this took a loong while.
    Schematic editing and picking parts took about 1 day, PCB layout took another one.
  • Introduction
    Alex Lungu07/11/2019 at 07:12 0 comments
    What is a scintillation counter? Why would anyone need one? What can it do?
    A scintillation detector is a type of radiation detector that relies on a characteristic of various materials called Scintillation. This is the ability of a material to convert high energy photons (such as X-rays or Gamma rays) to lower energy photons (usually blue light) with a direct correlation between the number of photons emitted and the energy of the incident X-ray or Gamma ray. This relationship between incident energy and output "brightness" of a scintillation event is critical for Gamma Spectroscopy.
    The light emitted by the scintilator is then picked up by a photomultiplier tube. PMT's are very interesting vacuum tubes and I can't possibly explain them in enough details here. In short, PMT's take in light and output a current proportional to the incident luminous flux.
    See where we're going? Energy to light output -> Light output to current -> current over a resistor to a voltage -> profit?
    That's the basics.
View all 6 project logs
  • 1
    Get all your parts
    Most of the parts can be ordered off Digikey/Farnell/Mouser/RS.
    Magnetics can be ordered as samples from Coilcraft, or bought from them directly.
    PMT and crystal can be bought off eBay.
    Boards can be ordered for cheap from PCBWay, JLCPCB or OSHPark.
    I've designed this project so as to use as few esoteric parts as possible.
  • 2
    Populate your boards
    Easy enough... A bit of SMD soldering, a few THT components, a PMT socket and you're set. The PMT socket should be mounted on the other side of the voltage divider (round PCB)
  • 3
    Test HV Power Supply
    You should measure the current draw of the supply (which should be <50mA under no load) and the voltage at the output (which you can adjust from ~600-1100V using the trimmer).
    Make sure nothing is getting hot.
View all 8 instructions
Rich text editor
hsfaiaz wrote 02/01/2023 at 03:05 point
I hope someone can send me the complete circuit?
Jonathan Samudio wrote 10/07/2020 at 14:33 point
Working on a version of this myself, and I'm a bit inexperienced on how one would go about testing the power supply once the construction is completed. Any tips?
Eric wrote 07/20/2019 at 02:07 point
Thanks!    On the schematic, you note "place only one resistor" at the feedback R2 and R5.  Do you mean either R2 or R5 is an 820R resistor with the other left as an open circuit, and that it does not matter which one is used?
Alex Lungu wrote 08/29/2019 at 10:49 point
Exactly. Place either one. It doesn't really matter that much, but if you, for whatever reason, find that the primary drive oscillator doesn't start oscillating, you can switch the resistor to the other side.
Tom Nardi wrote 07/12/2019 at 17:27 point
Saw this project on Reddit, happy to see you brought it here. If I recall correctly, you said you got the tube for some preposterous price at a flea market, right?
Awhile ago I bought a Hamamatsu H7155 for a few bucks on eBay, planned on doing a teardown article for it, but perhaps I would be better off powering it up. According to the seller it was never used, still has a little Hamamatsu sticker over the aperture.
Alex Lungu wrote 07/16/2019 at 11:41 point
Yep, got it for about 50 cents. Guy who sold it pretended to be an electronics expert and he was bragging about the PMT being a "worthless dual triode". Didn't contradict him on the worthless part, why would I?
