MAJOR UPDATE!!!
11/04/2024 at 20:37 • 0 commentsRecently I decided to make a major update to this project, with the end result essentially being the same but all of the components and code being updated/replaced.
Why you might ask? Partly just-because, but also largely because my son has gotten old enough to be a big fan of LEGO and space (and I happened to have bought a second Saturn V a long time ago), so it made sense to redo mine and then have an easier way to duplicate it for him (as well as a variation for his younger sister). Major changes include:
- The base/mount for the Saturn V is now completely 3D printed and also includes LEGO connection mounts (allowing for a loose fit, or if you remove a piece from each engine, a VERY snug fit).
- Switched the MCx to an ESP32 and now use ESPHome for the code
- Added internal speakers (as well as the line-out I had before)
- Swapped a few components, as the originals weren't natively compatible with ESPHome.
- Milled my own PCB
I've updated the Thingiverse link with the new 3D models in case anyone wants to use them as well as uploaded the KiCAD files for the PCB. Here's the ESPHome YAML (mostly-done, but still a bit of a work-in-progress):
esphome: name: lego-apollo-11 friendly_name: LEGO Apollo 11 esp32: board: esp32dev framework: type: arduino # type: esp-idf # Enable logging logger: # Enable Home Assistant API api: encryption: key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" ota: - platform: esphome password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: "Lego-Apollo-11 Fallback Hotspot" password: "xxxxxxxxxxxxxx" #Removed for Bluetooth Proxy feature #captive_portal: #bluetooth_proxy: # active: true #esp32_ble_tracker: status_led: pin: number: GPIO2 inverted: true button: - platform: restart name: Restart - platform: safe_mode name: Restart (Safe Mode) - platform: template name: "Launch" icon: mdi:rocket-launch on_press: - script.execute: sv_launch - platform: template name: "TLI" icon: mdi:rocket on_press: - script.execute: sv_tli - platform: template name: "Lunar Landing" icon: mdi:rocket-outline on_press: - script.execute: lunar_landing - platform: template name: "ABORT" icon: mdi:alert-octagon on_press: - dfplayer.stop - script.stop: sv_launch - script.stop: sv_tli - script.stop: lunar_landing - script.stop: timer_countdown - script.stop: timer_countup - script.stop: alarm_1202_1 - script.stop: alarm_1202_2 - script.stop: alarm_1201 - switch.turn_off: saturn_v_exhaust_plume - switch.turn_off: lunar_lander_exhaust_plume - light.turn_off: saturn_v - light.turn_off: lunar_lander - light.turn_off: alarm_1201_LED - light.turn_off: alarm_1202_LED - light.turn_off: fuel_led - light.turn_off: saturn_v_section_1_leds - light.turn_off: saturn_v_section_2_leds - light.turn_off: saturn_v_section_3_leds - light.turn_off: saturn_v_section_4_leds - light.turn_off: saturn_v_section_5_leds - light.turn_off: saturn_v_section_6_leds - light.turn_off: lunar_lander_section_1_leds - light.turn_off: lunar_lander_section_2_leds - light.turn_off: lunar_lander_section_3_leds - light.turn_off: lunar_lander_section_4_leds - light.turn_off: lunar_lander_section_5_leds - light.turn_off: lunar_lander_section_6_leds text_sensor: - platform: wifi_info ip_address: name: IP Address sensor: - platform: wifi_signal name: WiFi Strength update_interval: 60s disabled_by_default: true - platform: uptime name: Uptime disabled_by_default: true # Stuff for the clock display globals: # Affects how the countdown/countup timers are displayed - id: clock_display type: int restore_value: no initial_value: '1' - id: minute_1 type: int restore_value: no initial_value: '0' - id: minute_2 type: int restore_value: no initial_value: '1' - id: second_1 type: int restore_value: no initial_value: '2' - id: second_2 type: int restore_value: no initial_value: '3' time: - platform: sntp id: sntp_time display: platform: tm1637 id: tm1637_display clk_pin: GPIO16 dio_pin: GPIO17 length: 4 update_interval: 100ms lambda: |- static int i = 0; if (id(sv_launch).is_running() or id(sv_tli).is_running() or id(lunar_landing).is_running()) { if (id(clock_display) == 0) { // Blank Display it.print(" "); } else if (id(clock_display) == 1) { // Display single minute & seconds with '-' it.print(0, "-"); it.printf(1, "%i.", id(minute_2)); it.printf(2, "%i", id(second_1)); it.printf(3, "%i", id(second_2)); } else if (id(clock_display) == 2) { // Display full minutes & seconds, but exclude first minute it.print(0, " ");; it.printf(1, "%i.", id(minute_2)); it.printf(2, "%i", id(second_1)); it.printf(3, "%i", id(second_2)); } else if (id(clock_display) == 3) { // Display full minutes & seconds it.printf(0, "%i", id(minute_1)); it.printf(1, "%i.", id(minute_2)); it.printf(2, "%i", id(second_1)); it.printf(3, "%i", id(second_2)); } else {} } else { i++; if (i > 10) it.strftime("%H%M", id(sntp_time).now()); else it.strftime("%H.%M", id(sntp_time).now()); if (i == 20) i = 0; } if (id(lunar_landing).is_running() and (id(minute_1) == 0) and (id(minute_2) == 1) and (id(second_1) == 0) and ((id(second_2) == 0))) { id(fuel_led).turn_on().set_rgb(0.96, 1.0, 0.01).perform(); } else if (id(lunar_landing).is_running() and (id(minute_1) == 0) and (id(minute_2) == 0) and (id(second_1) == 3) and ((id(second_2) == 0))) { id(fuel_led).turn_on().set_rgb(1.0, 0, 0.06).perform(); } else {} light: - platform: neopixelbus type: GRB #GRBW variant: WS2812 #WS2812 #SK6812 pin: GPIO04 method: type: esp32_rmt channel: 0 # - platform: esp32_rmt_led_strip # rgb_order: GRB # pin: GPIO04 # rmt_channel: 0 # chipset: WS2812 num_leds: 60 restore_mode: ALWAYS_OFF name: "Saturn V" id: saturn_v icon: mdi:rocket # internal: true on_turn_on: - if: condition: - switch.is_on: saturn_v_exhaust_plume then: # Turn Off Entire Strip/Partitions - switch.turn_off: saturn_v_exhaust_plume # Turn the main strip back on - light.turn_on: saturn_v - platform: partition name: "Saturn V - Section 1 LEDs" id: saturn_v_section_1_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: saturn_v from: 50 to: 59 effects: - addressable_flicker: name: Flicker update_interval: 16ms intensity: 10% - platform: partition name: "Saturn V - Section 2 LEDs" id: saturn_v_section_2_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: saturn_v from: 40 to: 49 effects: - addressable_flicker: name: Flicker update_interval: 16ms intensity: 10% - platform: partition name: "Saturn V - Section 3 LEDs" id: saturn_v_section_3_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: saturn_v from: 30 to: 39 effects: - addressable_flicker: name: Flicker update_interval: 16ms intensity: 10% - platform: partition name: "Saturn V - Section 4 LEDs" id: saturn_v_section_4_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: saturn_v from: 20 to: 29 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Saturn V - Section 5 LEDs" id: saturn_v_section_5_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: saturn_v from: 10 to: 19 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Saturn V - Section 6 LEDs" id: saturn_v_section_6_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: saturn_v from: 0 to: 9 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: neopixelbus type: GRBW #GRB #GRBW variant: SK6812 #WS2812 #SK6812 pin: GPIO25 method: type: esp32_rmt channel: 1 # - platform: esp32_rmt_led_strip # rgb_order: GRB # pin: GPIO25 # rmt_channel: 1 # chipset: WS2812 num_leds: 6 restore_mode: ALWAYS_OFF name: "Lunar Lander" id: lunar_lander icon: mdi:rocket # internal: true - platform: partition name: "Lunar Lander - Section 1 LEDs" id: lunar_lander_section_1_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: lunar_lander from: 0 to: 0 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Lunar Lander - Section 2 LEDs" id: lunar_lander_section_2_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: lunar_lander from: 1 to: 1 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Lunar Lander - Section 3 LEDs" id: lunar_lander_section_3_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: lunar_lander from: 2 to: 2 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Lunar Lander - Section 4 LEDs" id: lunar_lander_section_4_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: lunar_lander from: 3 to: 3 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Lunar Lander - Section 5 LEDs" id: lunar_lander_section_5_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: lunar_lander from: 4 to: 4 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: partition name: "Lunar Lander - Section 6 LEDs" id: lunar_lander_section_6_leds icon: mdi:led-strip restore_mode: ALWAYS_OFF # internal: true segments: - id: lunar_lander from: 5 to: 5 effects: - flicker: name: Flicker alpha: 95% intensity: 5% - platform: binary name: "Alarm 1201 LED" id: alarm_1201_LED output: output_1201_led icon: mdi:alarm-light restore_mode: ALWAYS_OFF - platform: binary name: "Alarm 1202 LED" id: alarm_1202_LED output: output_1202_led icon: mdi:alarm-light restore_mode: ALWAYS_OFF - platform: neopixelbus type: RGB #RGB variant: WS2812 #SK6812 pin: GPIO23 method: type: esp32_rmt channel: 2 # - platform: esp32_rmt_led_strip # rgb_order: RGB # pin: GPIO23 # rmt_channel: 2 # chipset: WS2812 num_leds: 1 name: "Fuel LED" id: fuel_led icon: mdi:fuel restore_mode: ALWAYS_OFF # internal: true default_transition_length: 0s switch: # Saturn V Partition Effects Switch - platform: template name: Saturn V Exhaust Plume id: saturn_v_exhaust_plume icon: mdi:rocket-launch optimistic: true turn_on_action: - if: condition: or: - script.is_running: sv_launch - script.is_running: sv_tli then: # Do nothing else: - if: condition: - light.is_on: saturn_v then: - light.turn_off: saturn_v # Individual Partitions/sections - light.turn_on: id: saturn_v_section_1_leds brightness: 100% red: 100% green: 72% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_2_leds brightness: 100% red: 100% green: 60% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_3_leds brightness: 100% red: 100% green: 48% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_4_leds brightness: 100% red: 100% green: 36% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_5_leds brightness: 100% red: 100% green: 12% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_6_leds brightness: 100% red: 100% green: 0% blue: 0% transition_length: 1.5s - delay: 1.5s - light.turn_on: id: saturn_v_section_1_leds effect: Flicker - light.turn_on: id: saturn_v_section_2_leds effect: Flicker - light.turn_on: id: saturn_v_section_3_leds effect: Flicker - light.turn_on: id: saturn_v_section_4_leds effect: Flicker - light.turn_on: id: saturn_v_section_5_leds effect: Flicker - light.turn_on: id: saturn_v_section_6_leds effect: Flicker turn_off_action: - light.turn_off: saturn_v_section_1_leds - light.turn_off: saturn_v_section_2_leds - light.turn_off: saturn_v_section_3_leds - light.turn_off: saturn_v_section_4_leds - light.turn_off: saturn_v_section_5_leds - light.turn_off: saturn_v_section_6_leds # Lunar Lander Partition Effects Switch - platform: template name: Lunar Lander Exhaust Plume id: lunar_lander_exhaust_plume icon: mdi:rocket optimistic: true turn_on_action: - if: condition: - script.is_running: lunar_landing then: # Do nothing else: - if: condition: - light.is_on: lunar_lander then: - light.turn_off: lunar_lander # Individual Partitions/sections - light.turn_on: id: lunar_lander_section_1_leds brightness: 100% red: 100% green: 72% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_2_leds brightness: 100% red: 100% green: 60% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_3_leds brightness: 100% red: 100% green: 48% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_4_leds brightness: 100% red: 100% green: 36% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_5_leds brightness: 100% red: 100% green: 12% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_6_leds brightness: 100% red: 100% green: 0% blue: 0% white: 0% transition_length: 1.5s - delay: 1.5s - light.turn_on: id: lunar_lander_section_1_leds effect: Flicker - light.turn_on: id: lunar_lander_section_2_leds effect: Flicker - light.turn_on: id: lunar_lander_section_3_leds effect: Flicker - light.turn_on: id: lunar_lander_section_4_leds effect: Flicker - light.turn_on: id: lunar_lander_section_5_leds effect: Flicker - light.turn_on: id: lunar_lander_section_6_leds effect: Flicker turn_off_action: - light.turn_off: lunar_lander_section_1_leds - light.turn_off: lunar_lander_section_2_leds - light.turn_off: lunar_lander_section_3_leds - light.turn_off: lunar_lander_section_4_leds - light.turn_off: lunar_lander_section_5_leds - light.turn_off: lunar_lander_section_6_leds output: - platform: gpio pin: GPIO21 id: output_1201_led - platform: gpio pin: GPIO22 id: output_1202_led uart: tx_pin: GPIO19 rx_pin: GPIO18 baud_rate: 9600 dfplayer: script: - id: sv_launch mode: single then: - script.stop: sv_tli - script.stop: lunar_landing - script.stop: timer_countdown - script.stop: timer_countup - light.turn_off: saturn_v - light.turn_off: lunar_lander - switch.turn_off: saturn_v_exhaust_plume - switch.turn_off: lunar_lander_exhaust_plume - light.turn_off: alarm_1201_LED - light.turn_off: alarm_1202_LED - light.turn_off: fuel_led - dfplayer.play_folder: folder: 1 file: 1 # Start countdown timer - globals.set: id: clock_display value: '1' - globals.set: id: minute_1 value: '0' - globals.set: id: minute_2 value: '0' - globals.set: id: second_1 value: '3' - globals.set: id: second_2 value: '1' - script.execute: timer_countdown - delay: 22.5s - switch.turn_on: saturn_v_exhaust_plume - light.turn_on: id: saturn_v_section_1_leds brightness: 25% red: 100% green: 72% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_2_leds brightness: 25% red: 100% green: 60% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_3_leds brightness: 25% red: 100% green: 48% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_4_leds brightness: 25% red: 100% green: 36% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_5_leds brightness: 25% red: 100% green: 12% blue: 0% transition_length: 1.5s - light.turn_on: id: saturn_v_section_6_leds brightness: 25% red: 100% green: 0% blue: 0% transition_length: 1.5s - delay: 1.5s - light.turn_on: id: saturn_v_section_1_leds effect: Flicker - light.turn_on: id: saturn_v_section_2_leds effect: Flicker - light.turn_on: id: saturn_v_section_3_leds effect: Flicker - light.turn_on: id: saturn_v_section_4_leds effect: Flicker - light.turn_on: id: saturn_v_section_5_leds effect: Flicker - light.turn_on: id: saturn_v_section_6_leds effect: Flicker - delay: 7.5s - light.turn_on: id: saturn_v_section_1_leds brightness: 100% - light.turn_on: id: saturn_v_section_2_leds brightness: 100% - light.turn_on: id: saturn_v_section_3_leds brightness: 100% - light.turn_on: id: saturn_v_section_4_leds brightness: 100% - light.turn_on: id: saturn_v_section_5_leds brightness: 100% - light.turn_on: id: saturn_v_section_6_leds brightness: 100% # Keep script running until audio is done - delay: 30s # Keep script running so clock doesn't display until the countup would stop making sense - delay: 100minutes - id: sv_tli mode: single then: - script.stop: sv_launch - script.stop: lunar_landing - script.stop: timer_countdown - script.stop: timer_countup - switch.turn_off: lunar_lander_exhaust_plume - light.turn_off: lunar_lander - light.turn_off: alarm_1201_LED - light.turn_off: alarm_1202_LED - light.turn_off: fuel_led - dfplayer.play_folder: folder: 1 file: 2 # Start countdown timer - globals.set: id: clock_display value: '3' - globals.set: id: minute_1 value: '4' - globals.set: id: minute_2 value: '9' - globals.set: id: second_1 value: '4' - globals.set: id: second_2 value: '5' - script.execute: timer_countup # Added full SV startup here because using the normal startup with transition length messed things up (only added in case it's not already on) - switch.turn_on: saturn_v_exhaust_plume - light.turn_on: id: saturn_v_section_1_leds brightness: 100% red: 100% green: 72% blue: 0% transition_length: 0s - light.turn_on: id: saturn_v_section_2_leds brightness: 100% red: 100% green: 60% blue: 0% transition_length: 0s - light.turn_on: id: saturn_v_section_3_leds brightness: 100% red: 100% green: 48% blue: 0% transition_length: 0s - light.turn_on: id: saturn_v_section_4_leds brightness: 100% red: 100% green: 36% blue: 0% transition_length: 0s - light.turn_on: id: saturn_v_section_5_leds brightness: 100% red: 100% green: 12% blue: 0% transition_length: 0s - light.turn_on: id: saturn_v_section_6_leds brightness: 100% red: 100% green: 0% blue: 0% transition_length: 0s - light.turn_on: id: saturn_v_section_1_leds effect: Flicker - light.turn_on: id: saturn_v_section_2_leds effect: Flicker - light.turn_on: id: saturn_v_section_3_leds effect: Flicker - light.turn_on: id: saturn_v_section_4_leds effect: Flicker - light.turn_on: id: saturn_v_section_5_leds effect: Flicker - light.turn_on: id: saturn_v_section_6_leds effect: Flicker - delay: 20.7s - switch.turn_off: saturn_v_exhaust_plume # Keep script running until audio is done - delay: 35s # Keep script running so clock doesn't display until the countup would stop making sense - delay: 50minutes - id: lunar_landing mode: single then: - script.stop: sv_launch - script.stop: sv_tli - script.stop: timer_countdown - script.stop: timer_countup - switch.turn_off: saturn_v_exhaust_plume - switch.turn_off: lunar_lander_exhaust_plume - light.turn_off: saturn_v - light.turn_off: lunar_lander - light.turn_off: alarm_1201_LED - light.turn_off: alarm_1202_LED - light.turn_off: fuel_led # Clear clock - globals.set: id: clock_display value: '0' - dfplayer.play_folder: folder: 1 file: 3 - delay: 33s - switch.turn_on: lunar_lander_exhaust_plume - light.turn_on: id: lunar_lander_section_1_leds brightness: 100% red: 100% green: 72% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_2_leds brightness: 100% red: 100% green: 60% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_3_leds brightness: 100% red: 100% green: 48% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_4_leds brightness: 100% red: 100% green: 36% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_5_leds brightness: 100% red: 100% green: 12% blue: 0% white: 0% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_6_leds brightness: 100% red: 100% green: 0% blue: 0% white: 0% transition_length: 1.5s - delay: 1.5s - light.turn_on: id: fuel_led brightness: 100% red: 81% green: 96% blue: 100% # Start countdown timer - globals.set: id: clock_display value: '2' - globals.set: id: minute_1 value: '0' - globals.set: id: minute_2 value: '4' - globals.set: id: second_1 value: '0' - globals.set: id: second_2 value: '0' - script.execute: timer_countdown - light.turn_on: id: lunar_lander_section_1_leds effect: Flicker - light.turn_on: id: lunar_lander_section_2_leds effect: Flicker - light.turn_on: id: lunar_lander_section_3_leds effect: Flicker - light.turn_on: id: lunar_lander_section_4_leds effect: Flicker - light.turn_on: id: lunar_lander_section_5_leds effect: Flicker - light.turn_on: id: lunar_lander_section_6_leds effect: Flicker - delay: 90.75s # First 1202 alarm - script.execute: alarm_1202_1 - delay: 30.75s # Second 1202 alarm - script.execute: alarm_1202_2 - delay: 13s # Throttle Down - light.turn_on: id: lunar_lander_section_1_leds brightness: 50% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_2_leds brightness: 50% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_3_leds brightness: 50% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_4_leds brightness: 50% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_5_leds brightness: 50% transition_length: 1.5s - light.turn_on: id: lunar_lander_section_6_leds brightness: 50% transition_length: 1.5s - delay: 17.3s # 1201 alarm - script.execute: alarm_1201 - delay: 28.7s - delay: 30s - delay: 14.5s # Engine shutdown - light.turn_off: id: lunar_lander_section_1_leds transition_length: 1.5s - light.turn_off: id: lunar_lander_section_2_leds transition_length: 1.5s - light.turn_off: id: lunar_lander_section_3_leds transition_length: 1.5s - light.turn_off: id: lunar_lander_section_4_leds transition_length: 1.5s - light.turn_off: id: lunar_lander_section_5_leds transition_length: 1.5s - light.turn_off: id: lunar_lander_section_6_leds transition_length: 1.5s - switch.turn_off: lunar_lander_exhaust_plume # Stop countdown - script.stop: timer_countdown - delay: 50.5s - light.turn_off: fuel_led - id: alarm_1202_1 mode: single then: - repeat: count: 16 then: - light.turn_on: id: alarm_1202_LED effect: None - delay: 412ms - light.turn_off: alarm_1202_LED - delay: 412ms - id: alarm_1202_2 mode: single then: - repeat: count: 19 then: - light.turn_on: id: alarm_1202_LED effect: None - delay: 412ms - light.turn_off: alarm_1202_LED - delay: 412ms - id: alarm_1201 mode: single then: - repeat: count: 17 then: - light.turn_on: id: alarm_1201_LED effect: None - delay: 400ms # Changed from 412ms to try and get it to sync better. Needed to be faster - light.turn_off: alarm_1201_LED - delay: 400ms # Changed from 412ms to try and get it to sync better - id: timer_countdown mode: restart then: - delay: 1s - if: condition: and: - lambda: 'return id(second_2) == 0;' - lambda: 'return id(second_1) == 0;' then: - lambda: |- id(minute_2) -= 1; id(second_1) = 5; id(second_2) = 9; else: - if: condition: - lambda: 'return id(second_2) == 0;' then: - lambda: |- id(second_1) -= 1; id(second_2) = 9; else: - lambda: |- id(second_2) -= 1; - if: condition: and: - lambda: 'return id(second_2) == 0;' - lambda: 'return id(second_1) == 0;' - lambda: 'return id(minute_2) == 0;' then: - lambda: |- id(clock_display) = 2; - script.execute: timer_countup else: - script.execute: timer_countdown - id: timer_countup mode: restart then: - delay: 1s - if: condition: and: - lambda: 'return id(clock_display) == 2;' - lambda: 'return id(minute_1) != 0;' then: - lambda: |- id(clock_display) = 3; - if: condition: and: - lambda: 'return id(minute_2) == 9;' - lambda: 'return id(second_1) == 5;' - lambda: 'return id(second_2) == 9;' then: - lambda: |- id(minute_1) += 1; id(minute_2) = 0; id(second_1) = 0; id(second_2) = 0; else: - if: condition: and: - lambda: 'return id(second_1) == 5;' - lambda: 'return id(second_2) == 9;' then: - lambda: |- id(minute_2) += 1; id(second_1) = 0; id(second_2) = 0; else: - if: condition: - lambda: 'return id(second_2) == 9;' then: - lambda: |- id(second_1) += 1; id(second_2) = 0; else: - lambda: |- id(second_2) += 1; - script.execute: timer_countup -
Now with Home Assistant control
02/23/2022 at 20:01 • 0 commentsSince having originally created this project, I've discovered the amazingness that is Home Assistant.. I'm all-in on HA and am slowly including my homemade projects into it by adding the necessary code. I've uploaded the modified code to Github and renamed it since most folks probably won't care about this part.
If you aren't familiar with Home Assistant, check it out!
New project!
12/04/2019 at 19:51 • 0 commentsI created a mission control 'console' for controlling this project, and created a new project page for it. Check it out!
Update to LM Mount Piece
07/26/2019 at 00:21 • 0 commentsAfter a month+ of periodic removal and usage, the attachment point between the LEGO LM and the LM Mount printed piece got loose enough that the LEGO easily tipped. I adjusted the dimensions just a tad and it is now quite snug. All files on Thingiverse have been updated accordingly.
Ben Brooks
