Loko operates with 2 units: The Ground unit (receiver), and the Air unit (transmitter). The Air unit transmits navigation data to the Ground unit at a pre-configured time interval, and the Ground unit transmits the received data to a smartphone app via Bluetooth (iPhone only with this version). ?is an android version being developed, and if so, will an android version be available by the time the campaign ships? The app automatically shows the location of any Loko Air modules on a 2D map.
Example use-case for finding a lost drone
- Attach the Loko Air module to your drone and operate as you normally would.
- If your drone goes missing, turn on the Loko Ground Unit to search.
- Once the Ground unit receives signal from the Air unit, the location of the Air unit will appear on the Loko smartphone app.
- Follow the directions on the Loko app to recover your drone.
Features & Specifications
- Works anywhere you go
- No cellular signal or internet required
- No monthly fees
- Range +20km
- Locate lost objects with pinpoint accuracy.
- Up to 270 days battery life per charge for Air unit (battery life depends on how often the Air unit is set to transmit its location)
- Expandable up to 30 Air units per Ground unit
visit nolilab
Akio Sato
Radu Motisan
Ilya Egorov
After a long time, I've added many new features and also shared the source code on GitHub.
What's new:
GPS Logger Mode
1. Loko can now operate purely as a GPS logger. Users can disable radio transmission entirely and use the device only for GPS data logging.
Browser-Based Log Visualizer
2. I created a web-based log visualization tool that allows users to view and analyze recorded tracking data directly in their browser:
https://www.nolilab.com/loko-config-tool/
3. One-Click Firmware Updater
Firmware updates are now much easier with a new one-click update tool.
4. Improved Mapping Support
The Loko App no longer relies on Google Maps. It now supports Esri Maps and OpenStreetMap, and users can download map data for offline use.
5. Custom Map Support
The Loko App now supports custom maps, including KMZ and GeoTIFF formats.
6. User Interface Improvements
Many UI enhancements have been added, including the ability to:
7. Assign custom names to trackers
8. Change tracker colors
9. Adjust tracker icon sizes
10. Customize the map display experience
And much more
and all software and hardware completely open source.
https://www.nolilab.com/software/
