PCB Routing
When I first looked at this a few years ago, all I could really find was the "Channel" router algorithm. It was "as plain as day" that the "normal" auto-router was based on shortest path (or some variant), but not much was published.
The Channel Router
The Channel router is certainly an interesting problem. I looked at it for routing strip-board. Here is the concept, layout your components either side of a "channel" and the Channel router will link them up. Here is my proposed strip-board layout:
Note: the ICs can be replaced with individual components.
And here a typical "channel" wiring diagram:
Note: The Channel algorithm has been modified to suit the strip-board constraint of one wire join per location (or hole).
So it is possible to auto-route strip-board efficiently (from an algorithm point of view) but it is not that elegant (visually).
It might have a niche if the parts are also auto-placed. But at that point I did not feel as if this was going to be a "useful" project to continue.
Shortest Path
The shortest path algorithm is well known and I have used it n the past to determine truck haulage paths of open pit mines (yes I was a mining consultant in a past life). Here is an example (the white traces are the proposed truck haulage paths):
Note: the scale of this problem is quite large (i.e. about 10 km across).
So okay, I have used this algorithm before! So what is so hard about auto-routing?
AlanX
Hi Ken,
Added support for image rotation. So I have something useful now. Next would be to export the nets and the board outline.
Looking at my code, it is not great but it is functional. I read the S-Expr name and depth and what ever list item number I need. I join the fragments with associative arrays. Final I export the associative arrays for further processing. It is hard coded so I just need to know all the possible cases.
A LISP or Prolog programmer would probable only need a few 10s of lines of code to do the same job.
I have other things to do today, so I will have another look tomorrow.
I have designed a new version of my CP/M machine. This time with external timers and a UART. I have upgraded the flash drives from 32k to 256k. The only problem is I have only been able to auto-route a 4 layer board.
AlanX
