Op-Amp Explorer:
- 2 Channels
- One inverting channel
- One Non-Inverting Channel
- Utilizes very low cost LM741
- AC or DC Coupling Selection
- Adjustable Gain through R5 and R6 (Using variable resistors)
Op-Amp Explorer:
Explorer1.pdfPreview of theory section in kit manual.Adobe Portable Document Format - 391.08 kB - 08/08/2019 at 04:35 |
Hey everyone, I finally had some time to work on projects again, and reworked the Op-Amp explorer board. I changed the general layout to make it more intuitive for a beginner, the components are laid out on the board in representative locations from the schematic. There are now also test points, thanks to a suggestion made to me. This should allow for quick measurements from points in the circuit that were not accessible in the previous revision.
Hey everyone,
I have just completed the preliminary design for the Op-Amp Explorer 1, which will be referred to as OE-1. This is a board with one inverting channel, and one non-inverting channel. The most glaring change that needs to be made is to add the potentiometers to the layout, which are currently represented as resistors. I was hoping to find some small-format rheostats in place of the pots, but the potentiometers appear to be less expensive. Currently, the module is to be presented as a kit for assembly by the user. The only pre-assembled part are the SMD power decoupling capacitors on the back.
I am starting work on the power supply board, which should be done shortly. It uses a voltage divider, with a virtual ground with 7805 (+) and 7905 (-) regulators to give a +/- 5V output. This could be stepped up in the future with a beefier wall-wart, or ultimately, a boost regulator.
Please stay tuned for updates, and feel free to offer any input on the project that you may have.
Thank you! I just added some test points to the board and did some other rework based on your suggestion.
I'm glad you liked the idea. Best of luck with the project.
Hay man i wanted to say that this is an amazing idea and i hope you help beginners learn.
May i make a suggestion? I'm an electronics engineer and i currently work as a PCB designer. One of the things i like to do on prototypes (if i have the space for it) is to use a header as a "test point" for interesting signals. It may be a good idea to have something like that, so beginners can measure signals easier. Just as an example - test points directly on the inputs of the op amp.
Hope i was not too long winded with the suggestion?. Best of luck with your projects :)
