The Edulog module system aims to give an introduction to analog signal processing for those venturing into the world of electronics. I plan on completing several modules that introduce the concepts of amplifiers, filters, oscillators, and more. The first three modules to this system are the power module, op-amp amplifiers (inverting and non inverting), and filters (active lowpass, and highpass). Each module is intended to be assembled as a kit, and will include supplemental information, including assembly instructions, and background theory. This is intended to be a system for hobbyists and students alike.
Details
Op-Amp Explorer:
2 Channels
One inverting channel
One Non-Inverting Channel
Utilizes very low cost LM741
AC or DC Coupling Selection
Adjustable Gain through R5 and R6 (Using variable resistors)
Files
Explorer1.pdf
Preview of theory section in kit manual.
Adobe Portable Document Format -
391.08 kB -
08/08/2019 at 04:35
Hey everyone, I finally had some time to work on projects again, and reworked the Op-Amp explorer board. I changed the general layout to make it more intuitive for a beginner, the components are laid out on the board in representative locations from the schematic. There are now also test points, thanks to a suggestion made to me. This should allow for quick measurements from points in the circuit that were not accessible in the previous revision.
I do plan on ordering boards, and constructing this revision soon. Then, I will work on writing an assembly guide, and update the workbook. As always, feel free to contact me more suggestions and comments.
I have just completed the preliminary design for the Op-Amp Explorer 1, which will be referred to as OE-1. This is a board with one inverting channel, and one non-inverting channel. The most glaring change that needs to be made is to add the potentiometers to the layout, which are currently represented as resistors. I was hoping to find some small-format rheostats in place of the pots, but the potentiometers appear to be less expensive. Currently, the module is to be presented as a kit for assembly by the user. The only pre-assembled part are the SMD power decoupling capacitors on the back.
I am starting work on the power supply board, which should be done shortly. It uses a voltage divider, with a virtual ground with 7805 (+) and 7905 (-) regulators to give a +/- 5V output. This could be stepped up in the future with a beefier wall-wart, or ultimately, a boost regulator.
Please stay tuned for updates, and feel free to offer any input on the project that you may have.
Hay man i wanted to say that this is an amazing idea and i hope you help beginners learn.
May i make a suggestion? I'm an electronics engineer and i currently work as a PCB designer. One of the things i like to do on prototypes (if i have the space for it) is to use a header as a "test point" for interesting signals. It may be a good idea to have something like that, so beginners can measure signals easier. Just as an example - test points directly on the inputs of the op amp.
Hope i was not too long winded with the suggestion?. Best of luck with your projects :)
