1Step 1
You have to 3D print the parts and have the boards for the keyboards ready
2Step 2
start with soldering the diodes to the keyboards, then the tactile button switches
3Step 3
Connect the two PCF8574 to the keyboards (also join together the row pins) and set the address pins differently.
4Step 4
Go on with the power compartment - solder together the switch, LiPo, LiPo charger and boost converter
5Step 5
basically follow this tutorial to get the keyboard driver stuff ready
davedarko
