3d printed 8:1 planetary gear ratio actuator module with VESC firmware based circular motor driver
planet_gear_m0.65_T30.stlThis is correct file for planet gear.Standard Tesselated Geometry - 1.80 MB - 01/06/2020 at 13:51 |
3d_print_planetary_gear_190920.zip.001001 - 45.00 MB - 09/20/2019 at 07:30 |
3d_print_planetary_gear_190920.zip.002002 - 32.47 MB - 09/20/2019 at 07:30 |
You can check it here;
Repeatability Test
The fully 3d printed 8:1 planetary geared actuator is controlled by mj-vesc(https://hackaday.io/project/167706-mj...). The precise position servo control is done by goto control mode(https://hackaday.io/project/167706-mj...). In this video, it shows the repeatability of single actuator. The result shows that it guarantees sub 0.01mm accuracy (standard deviation : 0.0058mm measured at 150mm from actuator center)
Thanks for your comment. I will make some robot using this.
These look like they might be good actuators for a delta robot. Among other things, of course.
