Front Panel fully functional
10/05/2019 at 19:45 • 0 commentsHere's the old school front panel with modern twists. The front panel is controlled by a 32 bit RISC CPU over an I2C bus. Pushbuttons (cheaper than toggles) are used but made to function like toggles.
Front Panel Test
10/05/2019 at 16:53 • 0 comments -
Populated front panel board
10/05/2019 at 16:25 • 0 comments -
External SRAM Test Passed
10/04/2019 at 23:03 • 0 commentsThe external SRAM is tested from the PSoC.
It works! Yeah...
GitHub repository for PSoC code.
Added test of all 512KB. Takes about 1 second.
Backwards PSoC
10/04/2019 at 23:00 • 0 commentsI put in two chips backwards on the board. There's a big dot and a little dot. The little dot is pin 1. The big dot isn't.
After fixing that the PSoC programmed and I made the LED blink.
Started build
10/03/2019 at 01:02 • 0 comments -
PCBs are in
10/03/2019 at 00:19 • 0 commentsJLCPCB took less than a week. So quick I didn't order the parts before the PCBs arrived.
Schematic for PCBs ordered
09/27/2019 at 12:42 • 0 commentsThis is the schematic for the card as ordered.
Added
09/26/2019 at 22:00 • 0 commentsAdded terminators for the I2C (stuffing option). Added interrupt line for Front Panel design.
Added 2 pin header and RC filter for DAC output.
Did board route glossing. Here's the design. Getting ready to order PCBs.
Oscillator and MCP23017 are optional.
Ordered PCBs - Final Features
09/26/2019 at 11:48 • 0 commentsI ordered a batch of 10 boards from JLCPCB.
Final design has the following features:
- Z80 CPU - any speed from 4 MHz to 20 MHz should work
- 512KB Static RAM, 55 nS, Zero Wait State data and program memory
- PSoC5LP - Cypress Semiconductor System on a Chip
- $8 part
- 32-bit ARM CPU
- 5V logic levels - all glue logic in PSoC
- USB interface
- I2C interface with interrupt input line
- RTC with 3V 2032 battery
- Serial connections with handshakes (could use external FTDI or RS-232 transceiver)
- 8-bit DAC output
- Emulates Z80 peripheral chips in PSoC firmware
- Flexible Memory Mapper
- Maps the 512KB SRAM into the Z80's 64KB space
- Software-selectable bank sizes from 2K to 32KB
- Can be configured "on-the-fly" or by compiling PSoC code for particular software
- Z80 sets the banks with a write in I/O space - compatible with various software memory management schemes
- LED - controlled by PSoC
- Optional I2C Port Expander
- MCP23017
- Adds 16 bits of programmable I/O
- Optional oscillator
- Not required for most applications since PSoC controls all interfaces and has an accurate trimmed internal oscillator
- Connectors
- I2C
- USB B
- Serial TTL-level
- 95x95mm form factor with mounting holes
