Golden Axe with MOS 8580 R5 SID
12/12/2021 at 02:13 • 0 commentsOne of the greatest SID songs ever made - enjoy!
CPC MIDI Playback (MIDI IN Demo)
06/17/2021 at 22:33 • 0 comments -
Speak&SID in Concert - LineOut Recording of Classic SID Tunes
06/10/2021 at 04:16 • 0 comments -
A Tribute to the C64 - "Cosmic Force" Soundtrack on the CPC
07/15/2020 at 04:01 • 0 commentsI backed the "Cosmic Force" Kickstarter Project
https://www.kickstarter.com/projects/yousee3d/cosmic-force-c64-retro-shoot-em-up
and was super excited to receive the digital version this weekend. AND, it included a SID file! I really like the game, and the SID soundtrack is superb, great job, WavemStudios! Thanks, this is an enjoyable game with great music.
Here you: as a tribute to the mighty SID, the C64, and the great "Cosmic Force" game, let's listen to the soundtrack on the Amstrad CPC:
MIDI IN CPC SID + AY Synthesizer - First Version
12/05/2019 at 15:19 • 0 commentsHere is a first cut at the MIDI IN CPC SID + AY synthesizer - the SID and AY soundchip are slightly detuned from each other, for a strange reason I have not figured out yet. Maybe an ARMSID artifiact? Will try with my real 6581. Also, SID play is currenlty only 1 channel, whereas the MIDI synth uses AY 3-8912 all 3 channels. Stay tuned! Next I will add filter cutoff and resonance for the SID via CPC keyboard keys or MIDI controls. Apologies for poor keyboard playing, I play the guitar usually.
Whenever you think the project is done - you get a new idea...
12/03/2019 at 17:19 • 0 commentsWas just thinking - why not take advantage of the UART / Serial Port and try to turn this into a real time SID Synthesizer for the CPC? There are inexpensive UART MIDI breakout boards available
I have used that board before for LambdaSpeak 3 and MIDI IN.
Now, what the Speak&SID hardware and firmware needs to support in order to make this happen is the following:
- read incoming MIDI data from the AVR UART and buffer it in a ring buffer - and that is already implemented in Speak&SID, as well as a generic serial API that allows the CPC to retrieve the UART buffer content byte by byte, using a read cursor. This interface uses CPC / Z80 IO address / port
&FBEE
. The CPC data bus is latched and "buffered" by the CPLD, in both directions (for IOREQ writes: CPC -> CPLD -> AVR, and IOREQ reads: AVR -> CPLD -> CPC). - turn on the SID chip - the Speak&SID is turned on with a "SID ON" signal that is being generated by the AVR / ATMega. When that signal is given, the CPLD also decodes the address range
&FAC0 - &FADC
and routes all CPC / Z80 IO read/write requests in that range directly to the SID chip data lines; also passing the 5 lower bits of the IO address to the SID's address pins. The CPLD uses the "SID ON" and IOREQ and RD / WR signals in order to generate the SID's Chip Select Signal (~CS). - on the CPC side, the CPC needs to monitor the serial buffer and retrieve the incoming MIDI messages from the buffer, using the serial interface API at port
&FBEE
, then parse and process the MIDI messages, and translate them into corresponding SID register writes to make the sound heard. Since the SID is turned on when the "SID ON" signal is given, and each read / write within the&FAC0 - &FADC
IO address range goes directly to the SID, the CPC can just write these SID registers directly. - at first I was thinking that there might be Z80 / CPC databus contention since both the ATMega and the SID needs to be connected to the data bus, but then I realized that this is actually not the case, since the address ranges are disjoint and the data bus is immediately released after the IOREQuest, and the requests for SID and CPLD / AVR are sequential in nature. So I don't even need to turn off the "SID ON" signal for reading the data from the UART buffer, since the SID only claims the data bus via ~CS when "SID ON" AND IOREQ RD / WR AND the the port address is in the
&FAC0 - &FADC
range, and&FBEE
for the serial interface is different. - moreover, given that the CPC has to run a program that reads the MIDI messages from the buffer, and processes and translates them into corresponding SID register writes, that program can also feed the CPC's internal AY 3-8192 sound chip to play MIDI notes as well, hence resulting in a SID + AY real time synthesizer, with 6 channels in total. Obviously, methods of addressing SID and/or AY independently can also be implemented (e.g., using different MIDI channels).
So, it seems that the hardware and firmware of Speak&SID already supports almost everything that is required for this! Only a tiny change to the AVR firmware is required (I need to ensure that the SID chip is not turned off while the serial buffer is being read).
This hence mainly requires CPC software...I alread have a piece of CPC ASM Software that turn the CPC into an AY MIDI real time synthesizer (written for LambdaSpeak 3), and it should not be difficult to use that for the Speak&SID SID MIDI IN Synthesizer. More soon!
PCB Revision 2 Arrived and Tested!
12/02/2019 at 03:25 • 0 commentsIt was bugging me that the previous PCB revision had the SID chip upside down. So I bit the bullet and rearranged the layout a bit. The new PCBs worked out of the box. I also added GND copper fill to the PCB bottom (not sure it makes a difference, but seems to be good PCB design practice). Saifisfied with the PCB now, and declaring the hardware side of this project as done.
Firmware source code on GitHub.
11/11/2019 at 05:34 • 0 commentsSource code is online now. Still need to write the documentation. Stay tuned!
