Wiring diagram? Ok :)
01/02/2022 at 04:50 • 0 commentsSome people commented asking if I could share a final schematic or wiring diagram, so here is a rather simple wiring diagram of my final board.
Hope it helps some of you.
All done!
06/05/2021 at 06:05 • 0 commentsThe cheap plastic box I ordered on Amazon took quite some time to arrive... until I realized it was shipped from China.
The size is just perfect. I cut a few holes, one for plugging in a USB-C cable (to allow direct reprogramming without having to take everything out of the box), one for the cable from the air conditioner, and I added a small light pipe so the microcontroller LEDs could be seen. Everything was secured using my best friend number 2, hot glue.
The final result looks like this (the case held with Blu Tack):
I may redo the cable that connects to the air conditioner motherboard, but for now, I'm happy with how it looks.
That looks far better
05/29/2021 at 00:37 • 0 commentsDo you remember how my circuit looked before? It was basically just components on a breadboard, connections made with jumper wires, and a tiny power bank to supply power.
Now it looks like this:
I switched from an Arduino Pro Micro to a Seeeduino XIAO simply because I had a few on hand and wanted to make the final board as tiny as possible (it's only 40 x 60mm). The 7805 package size is definitely overkill for this circuit, but that was the only through-hole 5V regulator I had lying around.
I also ordered a tiny plastic case on Amazon, which should be delivered next week. I’ll finish the project with a log of the complete product.
And that's how it's done
05/25/2021 at 12:51 • 3 commentsI did it... I achieved my goal... I can now control my air conditioner from Home Assistant!
I'm so happy and proud of myself!Everything happened so quickly in just one week that I can hardly believe it. Here's a brief summary of what I did and how:
1. Using this GUI tool, I created a firmware with the following settings:
- Board type = CC2530
- Device type = End device without routing
- Status LED = P22, Sending reports
- Output 1 = P03, UART, Baud rate = 9600, Packet end = 0x0D
- Model ID = RAS-LJ22Y_ADPT (for an unique name)
- Set default reporting interval(s) = 60
- Update firmware's timestamp
2. Before closing the GUI tool, I used "Save custom converter for Z2M" to create the corresponding external converter for Zigbee2MQTT (see file A-C_Hitachi_converter.js).
3. I flashed my Zigbee module, powered it up and then moved to Zigbee2MQTT dashboard in Home Assistant to add it. It appeared as an unsupported device with the name "RAS-LJ22Y_ADPT", so I followed the indication on this page and added it without any issues.
4. Then I moved the external converter I previously created to /config/zigbee2mqtt/.
5. Back to Zigbee2MQTT dashboard, I went to Settings > External converters, entered the name of the converter, clicked "Submit" and restarted Zigbee2MQTT. The result is as follow.
6. I added a climate platform to my configuration.yaml following this documentation (see file climate_platform.yaml for more details.) and restarted Home Assistant.
7. In the meantime, I wrote a simple program that retrieves the air conditioner’s status every 2 seconds, compares it to the previously known status, and if different, sends the new status to Home Assistant in a JSON format. Additionally, this program sends setting commands to the air conditioner based on what it receives from Home Assistant (see file my_puny_program.ino for details).
8. Finally I added a "Thermostat card" in Lovelace and set the "Entity" to the climate entity I created.
I played a lot with this "Thermostat card", also played a lot with the infrared remote control and so far, everything works flawlessly, everything is in perfect sync. Only problem is how the material solution looks like for the moment...
It's... it's working... for real!
05/16/2021 at 08:28 • 0 commentsI spent my Golden Week holidays diving deep in this GUI tool, and after a week of trial and error, I finally managed to send and receive data from Home Assistant!
How do you ask?
- first, in Home Assistant, I switched from deCONZ to Zigbee2MQTT plus Mosquitto broker.
- using the GUI tool, I created a custom firmware with OUTPUT1 set to P0.2, configured to UART with a baud rate of 9600 and 0x0D as an end packet.
- I then flashed my Zigbee module with that custom firmware.
- in Home Assistant, from Zigbee2MQTT dashboard, I allowed devices detection by clicking "Permit join (all)".
- I then connected my Zigbee module to my FTDI USB to TTL Serial Adapter, powered it up and opened Termite on my computer.
- After about 20 seconds, a new device appeared in Zigbee2MQTT dashboard. I renamed it "Proto" and added it to Home Assistant.
- Then, I went to Configuration > Integrations > Mosquitto broker > Configure and in "Publish a packet", I wrote the payload "test" to the topic zigbee2mqtt/Proto/set/action.
- Like magic, the text "test" appeared in my Termite window.
- I returned to Home Assistant and this time, in "Listen to a topic", I entered zigbee2mqtt/Proto/action and clicked "START LISTENING".
- Back to my Termite window, I typed "test again" and... again like magic, the same text appeared in Home Assistant.
Following this small success, I read here and there about how air conditioners are typically controlled via Home Assistant, and it's all about creating a "climate entity" and using the "thermostat" card in Lovelace.
Thankfully, I found that there's a way to create such a climate entity when using MQTT: MQTT HVAC
Perfect! This week, I'm going to search for more examples on how to create such an entity and try to build on.Now that I’ve successfully transmitted data to Home Assistant, the overall connection diagram should look something like this:
Could that be the solution?!
05/03/2021 at 02:38 • 0 commentsToday, I took a closer look at some sites introducing DIY Zigbee devices and noticed something right away: the author is using the same Zigbee module as I am (E18-MS1-PCB from Ebyte).
In the past, I tried to look for projects or information about this CC2530-based module, but didn't find much. However, I thought it was worth another try since someone is actively building Zigbee devices with it.As usual, I used my best friend Google. Using the keyword "E18-MS1-PCB", I went right away to "Images" and after scrolling for a but, this caught my attention:
I mean... the image title speaks for itself, right? With high hopes, I clicked on the image and was directed to Z1 Mini Development Board lets you build custom ZigBee end devices. Unfortunately, after reading the article, I didn't find anything new on the horizon. To be sure, I checked the linked Wiki page, and there I found this:
Great firmwares? For the CC2530 chip... For a moment, I thought these might be the firmwares for the DIY Zigbee devices I mentioned earlier. Or maybe ready-to-flash firmwares to use a CC2530 as a ZNP device?
Well, it turned out to be even BETTER than that: A GUI tool for creating your own alternative Zigbee device with a flexible configuration of inputs and outputs.
This is incredibly promising and might be the solution I’ve been looking for to easily make a Zigbee device to enable connectivity for my air conditioner with Home Automation. I’ll be spending this Golden Week holiday diving into this!”
Long time no see ... (/ω\)
05/01/2021 at 02:22 • 0 commentsA bit more than a year since my last project log entry... shame on me. COVID-19 pandemic got me stuck in an unpleasant and depressfull work - eat - sleep repeat cycle. My procrastination reached it's highest of all time level and even completing or starting a new DIY project didn't seem to motivate me enough.
But I decided to put things in order and deal with my procrastination: completing this project while taking care of myself (personal training gym? skin care? improve my wardrobe?). Once this project is done, I will move to automate the other air conditioner I have and finally the small heater I bought last winter for my bathroom. From then I'm thinking to hack and improve the video intercom (bigger screen, adding a recording function, adding an auto-response function in case nobody is home, ultimately link it to HA?) but that's a story for another time.
Okey now let's talk about what's new since ... well since last year: last time I successfully flashed a cheap CC2530 based module with Z-Stack 3.0.2 but not knowing a thing about Zigbee I didn't know what to do next. So I went on a frenetic search of information, hoping I would be able to gather enough material from articles/forum messages/videos or whatever to understand how to properly communicate with a Zigbee router and implement that in a structure I could program.
Unfortunately the result was frugal:
- TI application report: Developing a ZigBee System Using a CC2530-ZNP
- Arduino program: water heater control using Xbee module
- NXP document: ZigBee Home Automation User Guide
- Github page of DIY Zigbee devices: DIY zigbee devices
- The same from the original author (Russian?): https://modkam.ru/
With that arduino program along with TI and NXP documents, I thought I could understand what should be done, in which order and manner but it turned to be far more difficult that I imagined and I gave up (at least for me it was too time consuming and fruitless).
So I turned my attention to public available litterature and bought the following book:
which turned out to be a waste of time and money as it isn't a practical development handbook as stated in the front cover but rather a book that explains in depth Zigbee standard, its functionality and its radio signal implementation.
Successful flashing of Z-Stack 3.0.2
08/02/2020 at 06:34 • 0 commentsI finally received my CC debugger (a cheap knockoff from AliExpress) and immediately set to work flashing my CC2530 module: success!
For those interested in the process, I followed this documentation on using the TI SmartRFR software to flash the module. The firmware I used was based on Z-Stack 3.0.2, built following this tutorial I mentioned before (you can download the hex file from the Files section: CC2530ZNP-with-SBL (Z-Stack 3.0.2).hex).
To check that the flash was successful, I used the TI Z-Tool software (don't forget to check "Scan all Enabled com ports (startup and manual scan)" in Tools > Settings > Serial Devices > Auto Scan).
While waiting for my CC Debugger to arrive, I looked around on the Internet for possible reasons why my previous attempts might have failed. Although I didn't find anything directly related, I decided to take a closer look at my components and found out the solder joint of D5 on my Wemos D1 mini was cracked... A quick rework and I successfully flashed the firmware using CC loader library (for those interested, I also uploaded the bin file in the Files section).
Zigbee, my future nemesis?
07/19/2020 at 06:09 • 0 commentsNow that I've demystified the communication protocol of the Hitachi air conditioner, it's time to tackle what is gonna be the most difficult and time-consuming part of this project for me: building a Zigbee interface to enable remote control from Home Assistant.
For the past month, I've been gathering information, learning the basics of Zigbee, searching for hardware solutions and trying to get a Zigbee module working. Here is a summary of my progress:
1) I learned there is three different types of devices in a Zigbee network: router, coordinator and end device. Because I want to go for a simple solution, I will make an "end device".
2) Searching for DIY Zigbee solutions led me to XBee modules and CC2530 based modules.
3) After considering the XBee modules, I found them to be too large for my needs. I then researched the CC2530, a System-on-Chip (SoC) made by Texas Instruments. It can be programmed directly (Intel 8051) and used stand-alone or flashed with specific firmware to function as a ZigBee Network Processor (ZNP) with an external MCU (like controlling an ESP8266 with an Arduino via AT commands). Since my 8051 programming skills were rusty and I wasn't interested in learning the SDK, I decided to go with the ZNP solution.
4) I searched for a CC2530-based modules on AliExpress and found a cheap and small transmitter/receiver module. Here is a link to the actual product: https://www.aliexpress.com/item/32803052003.html?spm=a2g0s.9042311.0.0.40bc4c4dzhaeel
5) I received the modules in about 2 weeks. I made a simple breakout board for one and tried to flash Z-Stack 3.0.2 following this excellent tutorial. Since I didn't have a CC debugger, I used an alternative flashing method with a Wemos D1 and CClib (source: Zigbee CCLib Flashing). The flashing was successful but the module UART didn't seem to work. I checked that P2_0 (CFG1) was tied to GND and I carefully followed the CC2530-ZNP power-up procedure described in Z-Stack ZNP Interface Specification, but I never got the SYS_RESET_IND from the module.
6) I tried reflashing the module using another programming method with CCLoader (tutorial: flashing CCLoader), but despite a successful flashing it still didn't work.
7) I tried flashing various firmwares (router, coordinator, stock) that I found on forums and GitHub using both flashing methods. I also tried flashing the second module I received, but none of the attempts got the UART working.
8) I've now ordered a CC debugger from China in the hope that the problem lies with the flashing method... Until I receive it, I plan to continue researching information about end device firmware, the Zigbee communication work-flow and Home Assistant integration.
Well... that was fairly easy
06/14/2020 at 03:10 • 1 commentYesterday, I hooked up the "central station" and recorded a bunch of data. I tried as many settings as I could, focusing on identifying how commands are sent to the air conditioner and how status are retrieved.
And after just two hours of opening PulseView files, extracting data and compiling everything in Excel here are the result.
- status inquiry
- RAC adapter message: MT P="address" C="checksum"[CR]
- air conditioner response: OK P="value" C="checksum"[CR]
- value setting
- RAC adapter message: ST P="address","value" C="checksum"[CR]
- air conditioner response: OK[CR]
That's all there is to it! The checksum calculation is straight forward, so I won't go into details here.
For a list of available addresses and possible values, check out the file "Analysis result (2020_06_14).xlsx".As a confirmation, I connected my FTDI USB to TTL serial adapter directly to the air conditioner, grounded the H-LINK pin and sent a few commands to the air conditioner: everything worked fine.
So the next step will be to learn about Zigbee communication system and explore how I can implement a wireless remote functionality in Home Assistant.
Florian
