1Preparing Pins
Materials:
- 2.85mm/3.0mm/3.175mm filament or rod (preferably made of nylon but other materials like wood, metal or other plastics may be used)
- 1.75mm filament (preferably nylon but other plastics may be used)Tools:
- Side cutters (also called flush cutters)
- A saw may be needed if cutting metal pinsPrints:
- Template_m.stlSteps
- Following the markings on the template_m.stl, use the guide to cut pins to specified lengths and quantities
Supercell
