It is strong enough
03/01/2020 at 14:23 • 0 commentsSo far this tambourine clamp has survived 3 different drummers this weekend. I'd say that is a success!
Prettifying and test fitting
02/24/2020 at 16:35 • 0 commentsI printed the clamp out of black PETG. This looks a lot nicer than my initial blue PLA prototype. It should also be a fair bit stronger. I placed a black norprene tube around the rim of the tambourine to dampen the impact of the drumsticks a bit.
The norprene tubing is 10mm outer diameter, 1.7 mm wall thickness.
