Improved Raspberry-Pi RGB Matrix Driver
Use Raspberry-Pi DPI hardware to drive four chains of RGB LED panels.
Custom driver board for HUB75, HUB75E, and Qiangli RGB panels. An Atmel XMEGA generates PWM, ABCDE, and LAT signals, while the raspberry-pi DPI generates the pixel clock and pixel data.
Uses Raspberry Pi DPI operating with 32MHz pixel clock.  (32MHz is the clock limit of the XMega)
  • Provides consistent panel timing regardless of CPU load.
  • Capable of drive large arrays with high refresh rate.
  • Software driver derives array dimensions from Linux framebuffer device, pwm bits, and panel type.
  • Panel CLK is produced by simple AND gate using pixel clock and DEN signal.
An Atmel XMega uses the pixel clock as it's external clock for synchronization.
  • Use HSYNC edge to capture scan line data from first few bytes of each scan line.
  • Generates PWM signal
  • Outputs row select bits
  • Generates LAT signal
Current Panel Configuration:
  • 48 Qiangli Q3F32 v4.1 panels (64 x 64, not hub75 compliant)
  • Canvas size: 768x256
  • Refresh Rate: 82Hz
  • Max OE active time: 49% at full brightness
driver3.sch
board schematic
sch - 646.65 kB - 02/26/2020 at 23:51
Download
driver3.brd
board layout
brd - 173.69 kB - 02/26/2020 at 23:51
Download
  • 1 × SN74LVC1G08DBVRE4 2-input AND gate
  • 2 × 74ABT16244ADL,112 4x 4-bit buffers with TTL inputs
  • 1 × 0402 330 Ohm Resistor
  • 1 × 0805 SMD LED
  • 11 × 0402 100nF Ceramic Capacitor
View all 8 components
  • New board assembled and tested
    Robert Rouquette06/13/2020 at 22:12 0 comments
    Had to fix some bugs in the XMega code, but the new layout appears to work.
  • New Circuit Boards
    Robert Rouquette03/09/2020 at 16:17 0 comments
    Received the new circuit boards today.
    Just need to populate them and verify the software updates.
  • Qiangli Q3F32 v4.1
    Robert Rouquette02/25/2020 at 23:48 0 comments
    The panels use the SM5266PH row select ICs.  These ICs are shift register based and make the panels incompatible with standard HUB75E ABCDE addressing.  The working panel pinout is as follows:
    • A - shift register clock, positive edge, should be clocked every row
    • B - shift register data, high -> row on, low -> row off, should set to high every eight row
    • C - blanking, timing/purpose unknown, should be kept low to enable outputs
    • D - async output enable, should be set to 3rd address bit
    • E - async output enable, should be set to 4th address bit
View all 3 project logs
Rich text editor
Aryabhat.ent wrote 02/11/2021 at 16:02 point
Hi
Please help me to add slowdown gpio setting for my panels
jerkwagon wrote 08/04/2020 at 21:28 point
i have a set of these boards, and i want to make an matrix using rpi-rgb-led-matrix, i noticed my new boards dont work like the old ones do, they are 5266 not 138.
Any advice how i can make these work? (mine are hub 75)
Robert Rouquette wrote 08/25/2020 at 21:35 point
This board is not compatible with the rpi-rgb-led-matrix library by hzeller.  It instead uses the DPI interface and the Linux framebuffer device to drive the GPIO pins.
