ArduiBox ESP is an enclosure set for ESP8266 (D1 Mini) or ESP32 (NodeMCU-32S). The heart is an additional pcb with integrated voltage regulator and breadboard. It fits together with the ESP module in a 4 module DIN rail enclosure.
Overview:
- milled 4 module DIN rail enclosure
- top shell with grey or transparent cover
- for EN50022 DIN rails
- pcb with 2x 20pole female pin header to plug the ESP module
- optional integrated voltage regulator (input voltage 9..35V via 2 way terminal block)
- breadboard / proto board for own circuits
- all GPIO pins are marked and placed beside the breadboard area
- 3x 2 way terminal blocks to connect external components to the breadboard
- removable protections for terminals
- Opening for modules USB port on top side
- for ESP8266 (AZ-Delivery D1 Mini) or ESP32 (NodeMCU-32S) only
