Hackaday.io Hackaday.io
Sign up Log in
3D printable Vacuum Cleaner
Powerful 3D printed Vacuum Cleaner. Almost everything is printed except motor, electronics and some screws. Motor & Electronics cost ~ 10$
marko-antonmarko anton
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
7 comments
14 followers
  • Description
  • Details
  • Files 7
    • View all
  • Components 4
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
1.6k
7
14
17
Team (2)
  • marko-antonmarko anton
  • aleksandrAleksandr
Join this project's team
hardware
ongoing project
3D printed vacuum vacuum cleaner cleaner Motor ac/dc recycle repairable
This project was created on 03/26/2020 and last updated 6 years ago.
Description
Did you ever wanted to make something really useful with 3D printer. Here is a vacuum cleaner.All you need is RS 545 motor and AC-DC converter, few screws and a filter.Other advantages of this vacuum cleaner other than being printed and cheep are, it can be repaired and upgraded.In future we will release a Vacuum cleaner on battery and vacuum cleaner for car that works on car power socket.https://youtu.be/BF4jt5-ldB8https://youtu.be/noaLUsivBwE
This work is licensed under a Creative Commons Attribution-ShareAlike 4.0 International License.
Files
openSucker_v0.1.FCStd
x-zip-compressed - 26.36 MB - 02/12/2021 at 20:02
Download
filter.stl
Standard Tesselated Geometry - 2.15 MB - 03/29/2020 at 08:29
Download
Handle.stl
Standard Tesselated Geometry - 7.75 MB - 03/26/2020 at 19:32
Download
Container.stl
Standard Tesselated Geometry - 4.62 MB - 03/26/2020 at 19:31
Download
Rotor.stl
Standard Tesselated Geometry - 3.08 MB - 03/26/2020 at 19:31
Download
View all 7 files
Components
  • 1 × Motor RS-545 12V
  • 1 × AC-DC converter 220 AC to 12 V
  • 1 × Slide button
  • 1 × Wires
Project Logs
Collapse
  • FreeCAD project uploaded
    marko anton • 02/12/2021 at 20:05 • 0 comments
    Uploaded FreeCAD project file. Plan is to make project parametric.
  • Initial publish
    marko anton • 03/29/2020 at 08:38 • 0 comments
    First stl files, some pictures and description
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
bmurch22 wrote 06/01/2022 at 20:30 • point
It's good to see the 3D project use it as a house cleaning device for sewage clean up households. I like it.
oksanazya wrote 11/27/2021 at 17:20 • point
I have tried the same way to make the 3D printed vacuum for my program. Learn more about it.
emisolersa wrote 03/25/2021 at 10:58 • point
it looks like a very different and unique idea I watched some of more similar projects here on https://cleanthese.com/
Florian Festi wrote 03/29/2020 at 21:40 • point
Nice project. But why not use a battery from am electric drill. As it is 3d printed it should be easy to support the most common brands.
fwacer wrote 03/30/2020 at 01:31 • point
Battery would likely increase the weight quite a bit, and would require more support structure (if I had to guess), which costs more filament. Certainly still an interesting modification idea
marko anton wrote 03/30/2020 at 11:38 • point
There is a plan to make a new version with a battery from a drill.  Stay tuned ;)
Florian Festi wrote 04/01/2020 at 07:59 • point
Nice!
The battery probably needs to go underneath the grip so it stays balanced in the hand.  You could have a mounting spot for various adapter plates there. Guess some flat, boxy batteries work best. Unless you want to have a stick battery that fits into the grip itself.
The first Submarine of the ESME
Project Owner Contributor
The SubesTM
matthiasMatthias
Stepper-Driven, MIDI-Controlled, Tonewheel Robot made with laser cut sheet metal tonewheels and custom-wound pickups
Hammond-Inspired Tonewheel Organ Robot
themixedsignalTheMixedSignal
This is a project in the final year student's graduation thesis defense.
3D file DIY Servo motor model
lossstarrylossstarry
3D printed toroidally wound axial flux permanent magnet air core motor. 3DTAFPM?
3D Printed Axial Flux Motor
colby-johnsonColby Johnson
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D printable Vacuum Cleaner", please tell us the reason.
Send message
Remove Member
