About Project
BMP280 Pressure Sensor Module
The BMP280 sensor module operates with the minimum voltage (VDD) of 1.71V, However, the previous version of this sensor modules operate on 1.8V (VDD).
The BMP sensor includes a Pressure sensing element, Humidity sensing element as well as Temperature sensing element which is then attached to Pressure front-end, Humidity front-end and temperature front-end. These front end IC’s are sensitivity analog amplifiers that are utilized in the process of the amplification of small signals. In this integration, the analog values are turned to digital voltage and this voltage is supplied to the logic circuits for further interface.
The BMP280 can be also utilized in mobile phones, tablets, PCs, Portable health care devices, GPS devices, home weather stations, etc. By using this procedure we can simply interface BMP280 with the Arduino.
