One day i was tired of buying fresh herbs, but unluckily i live in a apartment, where there is not direct sunlight most of the year.
Also i am a lazy guy and i wanted some kind of supervisor of the plant health and status, to track the plants, and automatize as much as possible, while its easy to setup
So i decided to create a tabletop planter which could give enough light to my plants, and also upload some stats and and images to a server.
Main features of first version:
- Smart home integrated (Homeassistant).
- custom PCB with only thru hole components (easy solder).
- Based on ESP32cam so plenty of implementation examples available.
- Fully 3d printed frame.
- High efficiency and dimmable LED Driver.
- 180 lm/W Led strips.
- Adjustable Height.
- OLED realtime status show.
- Easy OTA config with ESPHome, easy automation creation through nodered.
- I2C Pins exposed.
For a full guide take a look in my blog nkames
Niko
Arnov Sharma
gokux
vishal soni
Is there enough UV in the spectrum from those LEDs to give the plants what they need? Seems like grow lights always have a bit of a purple tinge to them, so I always assumed a little UV was needed.
