Diving into firmware
06/24/2020 at 11:51 • 0 commentsPut all the pieces together and finally build a working prototype.
Time to buy some seeds and test it in real conditions.
I used a ESPHome firmware to add the controller to HomeAssistant.
The next is to create some automations for the system in Nodered. -
First prototype built
06/12/2020 at 11:38 • 0 commentsIn last to months i have so far:
1 - Soldered all the components to the PCB board:
2 - Updated the design:
3 - Integrated the esp32 as a component to HomeAssistant using ESPHOME:
It was a success except for the camera integration.
4 - Mounted the first prototype:
So i´m ready to test it in next weeks :)
Started working on 3d pieces and rendered models
04/16/2020 at 15:53 • 0 commentsStarted working on 3d printed pieces, also i created some renders of the boards and setup
Sent to fabric first prototype PCB
04/16/2020 at 15:52 • 0 commentsI created a schematic, and using autodesk eagle i created a first prototype of the PCB.
