Hackaday.io Hackaday.io
Sign up Log in
BCD/Analog Clock
LED binary clock with analog meter for displaying time and date as a percentage.
miroslav-hancarMiroslav Hancar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
362
0
2
3
Team (1)
  • miroslav-hancarMiroslav Hancar
Join this project's team
  • video
completed project
hardware
clock microchip pic 8 bit
This project was created on 04/21/2020 and last updated 6 years ago.
Description
I designed this clock because i had a few unused analog ammeters with percentage scale and i was thinking it would be interesting to use them for displaying the time. This clock is based on Microchip's PIC16LF19175 which features a battery backed RTC to keep the time and date.
The clock is equipped with a very simple IR proximity sensor for activating the LEDs by hand. LEDs are turned off after 10 seconds to save the battery. Analog meter is driven by current source composed of DAC MCP4911, as a source of control voltage, and OPAMP MCP6031. The analog meter gradually displays percentage of day, week, month and year. Currently displayed percentage is indicated by two LEDs on the left side of pcb.
The clock is powered by a single AA cell but its voltage needs to be increased because 1.5V is too low for driving the LEDs. This is done by boost converter MCP16251 which generates 3.3V.
The battery run-time is approx. 6 weeks assuming the LEDs are activated only few times a day.
Details
Files
clock.sch
sch - 667.83 kB - 04/21/2020 at 12:06
Download
clock.brd
brd - 205.44 kB - 04/21/2020 at 12:06
Download
clock.hex
hex - 19.83 kB - 04/21/2020 at 12:06
Download
Log In/Sign up to comment
Sign up with Github
OR
A delightfully pixelated, programmable WiFi analog+digital clock... the size of a credit card
Project Owner Contributor
Foxie CardClock 2.0
will-fox-foxie-productsWill Fox (Foxie Products)
This LED matrix clock displays the current time using signals received from the GNSS satellites orbiting the earth!
Digital Satellite Clock
cpknightcpknight
Create a fully functional LED clock from schematic to PCB using only a web browser and EasyEDA Pro.
The Clock Project
robert-feranecRobert Feranec
The 2018 Hackaday Prize
Tix Clock Implemented In a Gem Mine Diorama
Tix Clock Gems
chris-chungChris Chung
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "BCD/Analog Clock", please tell us the reason.
Send message
Remove Member
