Features
- Minimal jumper wires, 4 on a mini breadboard
- Personalization via LED placements and leg lengths
- Battery operated from 3V
- Use of 32Khz clock crystal to keep time, power-down sleep mode (LPM3) takes less than 1uA power
Parts list
- 170 tie point mini breadboard
- MSP430G2412 (or other G/F series dip 20 pin devices w/ 4k flash)
- Lots of LEDs (1 blue, 9 green, 6 yellow, 9 red)
- Tactile button
- 32Khz clock crystal
- CR2032 button cell holder (battery not included)
Application Notes
- Single button press shows time for a few seconds, TCG returns to sleep after that
- Long press setup time, starting with the hours, related LEDs starts to blink
- Short press advance the hour value. Another Long press confirms the entry
- The tenths of the minutes and the minutes are subsequently entered like the hour
- Once the hours and minutes (tenths and singles) have been entered, TCG returns to show mode
Breadboard Layout
Schematic
Assembling
- Follow breadboard layout and place jumper wire on mini breadboard
- Place MSP430G2412 on breadboard
- Place Tactile Button
- Cut your LEDs into different lengths, *be sure to maintain one leg longer
- Place LEDs in groups of (1..9), opposing pairs on the same pin can be swapped for effect. Ex at b0-b1 #3 and #8 can be swapped. The "+>" is the blue LED indicating 10+ hours
- Place Battery Holder
Source code
Source code usually resides on my github repository. https://github.com/simpleavr?tab=repositories
source code not yet available. needs cleaning up.
Chris Chung
Simon
Robert Gill
