BlueoothServerPiFiles.zipThe altered rfcomm-server.py that should be placed in the pybluez/example/simple/ directory. As well as the shell script to turn on Bluetooth and run that server script.x-zip-compressed - 1.96 kB - 05/20/2020 at 14:58 |
Hardware PCB Schematic diagram.pdfA detailed prototype PCB schematic for the hardware integration. From Ben Jacobs' engineering notebook.Adobe Portable Document Format - 1.05 MB - 05/14/2020 at 19:54 |
Audio Subsystem Files 5-12-20.zipFiles pertaining to the Audio Codec Subsystem, including the PureData config file, run_pd.sh, a sample effect, and the two versions of the knobs object.x-zip-compressed - 2.86 kB - 05/12/2020 at 16:49 |
Human Interface Files 5-12-20.zipFiles pertaining to the Human Interface Subsystem, including the knobs Python script and schematics and block diagrams.x-zip-compressed - 105.90 kB - 05/12/2020 at 16:40 |
config.txtBoot configuration for the Raspberry Pi. Pertinent to subsystems which use i2c, SPI, and Audio.plain - 1.62 kB - 04/29/2020 at 22:23 |
Ben Jacobs
