Hackaday.io Hackaday.io
Sign up Log in
3D Printer Clog Detector
This is a small device that detects a nozzle clog during a print and alerts you to minimize time loss.
elite-wormElite Worm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.7k views
6 comments
20 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 6
View Gallery
1.7k
6
20
23
Team (1)
  • elite-wormElite Worm
Join this project's team
  • Code
hardware
completed project
clog sensor clog detector jam detector jam sensor filament detector filament sensor
This project was created on 05/12/2020 and last updated 6 years ago.
Description
I designed this small device to be able to alert me in the unfortunate event the nozzle clogs. It does so by monitoring the flow of the filament during the print and emitting an acoustic signal if it stops during 7 minutes or more.
Details
Log In/Sign up to comment
Sign up with Github
OR
darreldurose42 wrote 12/01/2021 at 15:15 • point
I was thinking of designing a clogged sensor just like this... well done!
dryphi wrote 05/20/2020 at 03:52 • point
This is great work. Would you describe this as a "photoelectric filament sensor"? Looks very similar to what they implemented on the CR-6 SE (about halfway down the page):
https://www.creality.com/cr-6-se-3d-printer-crowdfunding-on-ks-now-p00296p1.html
I am glad there's a "DIY" version though and can't wait to see the updates :)
TheGrim wrote 05/14/2020 at 15:20 • point
I like it. Good job.
Elite Worm wrote 05/17/2020 at 10:51 • point
I'm glad that you like it.
Dan Maloney wrote 05/12/2020 at 21:54 • point
I love this design! So simple and clean, and you've got lots of great build details in there. I really like the use of the balloon piece for friction on the encoder wheel. Great job!
Thank you Dan!
Everyone need an heated chamber, to be able to 3D print some difficult plastics from time to time. Here is a definitly simple solution.
Project Owner Contributor
Zatsit's Ultra Simple Heated Chamber
marc-peltierMarc Peltier
This allows you to change filaments during print with 100% success without any issues.
3D Printer Filament Window
robopandapdxRoboPandaPDX
This is the second version of a device I designed to alert me in the unfortunate event the nozzle clogs. It communicates with the printer!
3D Printer Clog Detector V2
Installing a peltier device (TEC) in place of the 40mm cooling fan of an all metal extruder.
Better Cooling for 3D Printer Extruders
brandon-langdonBrandon Langdon
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Printer Clog Detector", please tell us the reason.
Send message
Remove Member
