firmware(BL).binFirmware for the HSL E5-001 printer (No filament sensor, BL Touch enabled)octet-stream - 193.46 kB - 09/01/2020 at 17:17 |
Configuration(BL).hConfiguration.h for the HSL E5-001 printer (No filament sensor, BL Touch enabled)h - 599.00 bytes - 09/01/2020 at 17:17 |
firmware.binFirmware for the HSL E5-001 printer (No filament sensor, no BL Touch)octet-stream - 179.42 kB - 06/20/2020 at 01:17 |
Configuration.hConfiguration.h for the HSL E5-001 printer (No filament sensor, no BL Touch)h - 421.00 bytes - 06/20/2020 at 01:18 |
Marlin-1.1.x(1).zipMarlin 1.1.9 for use with stock Creality V1.1.9 boardx-zip-compressed - 4.78 MB - 06/20/2020 at 08:11 |
teachingtechender5v2.zipTeaching Tech Ender 5 config files for use with Creality V1.1.9 boardx-zip-compressed - 50.27 kB - 06/20/2020 at 08:12 |
TH3D EZBoard Documentation.pdfTH3D EZBoard installation manual.Adobe Portable Document Format - 1.32 MB - 06/19/2020 at 22:09 |
Part_Cooling_Fan_Duct_V1.4_Upper_Half.stlCreality Endehttps://cdn.hackaday.io/files/1716997345970016/Part_Cooling_Fan_Duct_V1.4_Upper_Half.stlr 5 Part Cooling Fan Duct (Upper Half) by ShaunTheBaahttps://www.thingiverse.com/thing:4262259 Standard Tesselated Geometry - 175.96 kB - 09/01/2020 at 17:20 |
Part_Cooling_Fan_Duct_V1.4_Lower_Half.stlCreality Ender 5 Part Cooling Fan Duct (Lower Half) by ShaunTheBaahttps://www.thingiverse.com/thing:4262259 Standard Tesselated Geometry - 184.46 kB - 09/01/2020 at 17:18 |
back_left_cover.stlEnder 5 Y-Axis belt cover (Rear Left side) by D_jespersenhttps://www.thingiverse.com/thing:3412007 Standard Tesselated Geometry - 1.96 MB - 05/26/2020 at 22:21 |
front_right_cover.stlEnder 5 Y-Axis belt cover (Front Right side) by D_jespersenhttps://www.thingiverse.com/thing:3412007 Standard Tesselated Geometry - 1.88 MB - 05/26/2020 at 22:20 |
front_left_cover.stlEnder 5 Y-Axis belt cover (Front Left side) by D_jespersenhttps://www.thingiverse.com/thing:3412007 Standard Tesselated Geometry - 1.88 MB - 05/26/2020 at 22:18 |
Arm_RH_Remix1.stlEnder 5 Bed Supports (Right side) by BoothyBoothyhttps://www.thingiverse.com/thing:3661405 Standard Tesselated Geometry - 724.40 kB - 05/26/2020 at 22:17 |
Arm_LH_Remix1.stlEnder 5 Bed Supports (Left side) by BoothyBoothyhttps://www.thingiverse.com/thing:3661405 Standard Tesselated Geometry - 708.38 kB - 05/26/2020 at 22:16 |
Back_Plate_Remix1.stlEnder 5 Bed Support Back Plates (both sides) by BoothyBoothyhttps://www.thingiverse.com/thing:3661405 Standard Tesselated Geometry - 1.07 MB - 05/26/2020 at 22:22 |
X_Axis_Gantry_Cover_right.stlEnder 5 X-Axis belt cover (Right side) by D_jespersenhttps://www.thingiverse.com/thing:3465579/ Standard Tesselated Geometry - 454.48 kB - 05/17/2020 at 06:02 |
X_Axis_Gantry_Cover_Left.stlEnder 5 X-Axis belt cover (Left side) by D_jespersenhttps://www.thingiverse.com/thing:3465579/ Standard Tesselated Geometry - 365.90 kB - 05/17/2020 at 06:02 |
Insulation_Frame.stlCable protection for Ender-5 by lgagahttps://www.thingiverse.com/thing:3354725/ Standard Tesselated Geometry - 1.03 MB - 05/17/2020 at 06:00 |
Ender-5_Bed_Strain_Relief-V2.stlEnder-5 Bed Strain Relief by derandi3dhttps://www.thingiverse.com/thing:3443100/ Standard Tesselated Geometry - 160.73 kB - 05/17/2020 at 05:59 |
