1Viewing project logs in chronological order.
I have attempted to use my project logs to show the build as it happened, so I think the best way if you wish to replicate the machines seen here, or need to know how they went together is to start at the beginning before we had the printers, what was done then, and following the build of the printers as the parts came in.
https://hackaday.io/project/171699/logs?sort=oldest
^ This link should do the trick! :)
Let me know if there's anything I need to put into the logs for completeness, or anything I can do better to convey what might not have been written or said! Maybe if something can be done better we can add that too!
Sometimes it's hard to document each and every step and I miss one or more!
