The 4th Axis Super Saver needs a base plate to be easily set on the bed of the machine.
AutoCAD DXF - 353.43 kB - 05/22/2020 at 17:38
AutoCAD DXF - 167.46 kB - 05/22/2020 at 17:38
f3z - 1.22 MB - 05/22/2020 at 16:28
step - 297.78 kB - 05/22/2020 at 16:28
step - 403.80 kB - 05/22/2020 at 16:28
View all 6 files
two $20 car jacks, a $40 stool, and a $20 motorcycle jack worked great for lifting and removing the unit Into and Out-of the machine. The only annoyance was the clearance for bolt to the Jack Stand and Stool.
View all 4 project logs
Isaac Zammit
3D Meister
Federico Virdia
mbasecnc
Yes, delete it Cancel
You are about to report the project "Tormach Super Saver 4th Axis Base Plate", please tell us the reason.
