1Build Instructions
The board is using a mix of SMD and THT components but everything can be solder with a simple soldering iron, starting with all the SMDs before the through hole components on the top face and then the bottom face.
2Plugin configuration
The board was design to be used with the Enclosure plugin, of course you should start by installing it.
Configuration is done by going into Settings/Enclosure Plugin, here you can configure inputs and outputs as you want.
GOODWIN
