Hackaday.io Hackaday.io
Sign up Log in
dsPIC development board
Simple DSP devboard
miroslav-hancarMiroslav Hancar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
7 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
236
1
7
8
Team (1)
  • miroslav-hancarMiroslav Hancar
Join this project's team
hardware
ongoing project
microchip dspic dsp signal processing digital filter FIR IIR
This project was created on 06/20/2020 and last updated 6 years ago.
Description
This development board is one of my older projects (built on homemade PCB) and is especially useful in testing digital filters. It's designed for dsPIC33FJ32GP202 but can be used with many other dsPIC in 28 pin DIP package as well.
The board is equipped with 16 bit ADC LTC2364, 16 bit DAC LTC2642 and USB interface (COM port). AC input signal is shifted and centered at 1,65V with OPA365. The same opamp is used for buffering the output of the DAC.
There are no anti-aliasing and anti-imaging filters on the board but they can be connected to 5-pin IN/OUT headers. I had designed a "plug and play" filters for this purpose but, unfortunately, i can't find them anymore.
There is also a I2C header for connecting external sensors.
Details
Files
DSPboard.sch
sch - 968.10 kB - 06/20/2020 at 13:41
Download
DSPboard.brd
brd - 185.22 kB - 06/20/2020 at 13:41
Download
Log In/Sign up to comment
Sign up with Github
OR
Mike Szczys wrote 06/22/2020 at 18:55 • point
That home etched board came out looking great!
18-pin Enhanced FLASH/EEPROM 8-Bit Microcontroller Breakout Board
Project Owner Contributor
PIC16F84A Breakout Board
maals-labMAAL's LAB
Students build their own development boards, then they own the boards and can hack them. Thanks, Sean Carroll.
PIC32 student development boards
bruce-landBruce Land
A board for familiarization and early development
Fanout Board for ATSAMD21E18 MCU
bharbourBharbour
The 2018 Hackaday Prize
A small board for the Attiny85 and pin compatible variants for embedding into projects.
Attiny Micro
mcunerdmcu_nerd
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "dsPIC development board", please tell us the reason.
Send message
Remove Member
