11Connect the TankServer to a Playstation 2
12Configure OPL
Using a memory card with FreeMC boot installed boot the PS2 to the OPL and configure to the parameters you have used on your system.
Many tutorials are based on fixed IP but that is not necessary as long as both the NetBios name and the Share folder are inserted with the correct case.
13If everything is ok the list with the games installed on SSD will appear on OPL screen
