Lanyard Hint
08/04/2020 at 20:08 • 0 commentsThis tweet is apparently directed at the lanyard:
Google translate yields:
Korea is divided into north and south. They speak the same language and have the same customs. And, it's the same people. It must be peacefully unified. To do that, we need to have a conversation with each other. That is the way to live. “I love each other”
Possible the top halves of the lanyard need to in fact be AND/OR/XOR/something'd.
psmitty7373 Has solved the other text from the sleeve
07/29/2020 at 17:23 • 1 commentThe l (elle) was in fact an upper case I (eye)
"" I believe tlstFCOnRFoofFioumYrgureoohrDOuntlon is a route transposition and decodes to the message "ComeOnFourDotForIsRightInFrontOfYou" ""
t I s t F C O n R F o o f F i o u m Y r g u r e o o h r D O u n t I o n
31 25 19 13 7 1 32 26 20 14 8 2 33 27 21 15 9 3 34 28 22 16 10 4 35 29 23 17 11 5 36 30 24 18 12 6
t l s t F C
O n R F o o
f F i o u m
Y r g u r e
o o h r D O
u n t l o n*Edit formatting
Transcribing 1o57 ciphers from liner notes
07/24/2020 at 20:11 • 3 commentsHere are the dumps of messages from 1o57 in the liner notes:
Xbaw maek wzme pgty zvxy izwk iwhk lnhy agrl rrlp fsis xadh uflx dsqh rzrg qegu itwb wveq aslo moii xmzx mvea rtil yekd lvks jrbo arvy nmjz wodi gcxe tkrr cyir xbsu rwyf slwr ixyk lrwz sbzr zbpg rrrw hjsi alXX 1o57
There is a possibility that the lower case L that I used in these is actually an upper case I.
Update: @Lord Kiba has found one solution for this:
What's up people!
I believe I solved the transcribed text from cassette case it's a keyed Vigenere Cipher
Key is : "NOMATTERWHEREYOUGOTHEREYOUARE"
Decoded text is as follows "Know that as in life there is much that many have looked upon but few have seen because as my father told me and his father told him you will come to learn a great deal if you study the insignificant in depth "
