MrkII TechSpider
A Medium cost, open-source, 3D printed, quadruped robot platform for researching and fun
The MrkII TechSpider is an open-source, 3D printed, quadruped robot platform.
The front is designed to be customizable for any type of module. There for the modules can be easily swaped. On the backside is a container for the microcontroller. This will change to a smaller version, or can be designed smaller, that depends on which controller you like to use.
The robot is designed for a minimum build area of 140x140mm
Used material is PLA with a 0.4 nozzle and 30% infill.
To prevent unnesesary copies and not up-to-date file, there for all files are central accessible on the link below:
https://github.com/TechSpiderbot/MarkII
  • BOM of all hardware
  • STL files
  • Captured images
  • PCB Gerber files
  • Software for each module and a early neuro network function
Portable Network Graphics (PNG) - 428.52 kB - 04/02/2021 at 23:19
Preview
TechSpider Front Distr PCB
JPEG Image - 5.62 MB - 08/09/2020 at 19:28
Preview
TechSpider Backside Distr PCB
JPEG Image - 3.82 MB - 08/09/2020 at 19:28
Preview
TechSpider NUCLEO-F411RE SHIELD PCB
JPEG Image - 4.35 MB - 08/09/2020 at 19:28
Preview
TechSpider Front Connector PCB
JPEG Image - 4.02 MB - 08/09/2020 at 19:28
Preview
View all 9 files
View all 2 project logs
TechSpiderbot wrote 08/28/2020 at 05:55 • point
The caps help for now against weird movements from the servos by starting up, because the servos ask totally a high current when powering on from my power supply.
Jacob David C Cunningham wrote 08/29/2020 at 01:21 • point
Oh man! I have that problem too haha, or at least while my ESP is binding to the WiFi it jitters the same as the blue led blinks then stabilizes.
Jacob David C Cunningham wrote 08/25/2020 at 19:41 • point
man that thing is hot! haha, did you consider masses/moments on the servos? Seems like all your servos are the same size. The 4-legs is interesting, I'm guessing it is like a tripod where 1 leg moves a time?
TechSpiderbot wrote 08/28/2020 at 03:53 • point
yes all servos are the same size except the coxa joint. It could be programmed like a tripod for walking. But giving it a learning algorithm can be interesting to see how it will evolve moving through obstacles.
Jacob David C Cunningham wrote 08/28/2020 at 05:04 • point
I just noticed the caps, are those functional? Looks cool. The learning thing is interesting, I personally am looking into the obstacle thing myself. A house has irregular objects, some harder to detect than others vs. just a wall.
