22.01.2021 - Voron Switchwire - Electronics Mounting
01/22/2021 at 17:11 • 0 commentsVoron Switchwire - Electronics Compartment
(with additional 12VDC PSU for Fans, Leds...) -
19.01.2021 - Voron Switchwire - Heat Bed Wiring and Crimping
01/19/2021 at 11:15 • 0 commentsMy Voron Switchwire - 19.01.2021 Voron Switchwire - Heat Bed Wiring Voron Switchwire - Heat Bed Connectors
I have used insulated Ring Terminal Connectors, 2xM4 8mm with self locking nut.
Cables: 2 x 1.2m (black and red) 1-core 16 AWG Silicone WireVoron Switchwire - Y-Endstop (white 3-pin JST-XH) and Bed Thermistor Connectors (Red 2-pin JST)
Cables: 1 x 1.2m 4-core 24 AWG Silicone Parallel Wire (Black) -
18.01.2020 - Voron Switchwire - X & Z axis Wiring and Crimping
01/18/2021 at 11:40 • 0 commentsVoron Switchwire - X cable chain wiring Voron Switchwire - Afterburner connectors - my alternative for Molex Microfit 3.0 JST Connector Plug 2pin Female, Male and Crimps
Voron Switchwire - X-axis Endstop Omron Microswitch witch JST-XH 2.54 connector X and Z cable chain line: 3 x 1.5m 5-core 24 AWG Silicone Parallel Wire (Black) and 2 x 1.5m (red) 1-core 18 AWG Silicone Wire -
15.01.2021- Voron Switchwire Magnetic Heat Bed MK52
01/15/2021 at 14:46 • 0 commentsVoron Switchwire - Double sided Textured PEI Spring Steel Sheet for Prusa MK52 - TriangleLab Voron Switchwire - TriangleLAB 24V PRUSA i3 MK3 MK3S up to 130°C continuous Heated Bed spring steel plate Voron Switchwire - FYSTEC - 6x6x3mm Aluminum Spacers TriangleLAB - Prusa MK52 Heated Bed - 24V
My Voron Switchwire BOM: https://hackaday.io/project/174810/components
05.01.2021 - Voron Switchwire - X and Z Cable Chains
01/05/2021 at 12:20 • 0 commentsVoron Switchwire - X and Z Cable Chains
10*11mm Mini Energy Chain - Nylon Drag ChainVoron Switchwire - Cable Chain - Z-axis Voron Switchwire - Cable Chain - X-axis Voron Switchwire - Z-axis Cable Chain Lower Mount Voron Switchwire - XZ Cable Cover
My Voron Switchwire Bill Of Materials (with links): https://hackaday.io/project/174810/components -
04.01.2021 - Voron Switchwire - KeyBak
01/05/2021 at 11:47 • 0 commentsKeyBak Super48 in Voron Switchwire 3D printer prevents the X-axis level from going down when XZ motors are off.
My Voron Switchwire Bill Of Materials: https://hackaday.io/project/174810/components
03.01.2020 - Voron Switchwire - Afterburner - Cooling Fans Assembly
01/03/2021 at 10:58 • 0 commentsVoron Switchwire - Afterburner - Cooling Fans Voron Afterburner - 3D Printed Blower and Fan Housing Voron Afterburner - Blower and Fan Housing - Assembly - Front Voron Afterburner - Blower and Fan Housing - Assembly - Back 40x20x20 Centrifugal Blower Fan - GDStime 24V, Dual Ball (Front of the blower housing has to be removed before install in Voron Afterburner Cooling Fan Housing) Axial Fan 40x40x10 Noctua NF-A4x10 FLX 4500RPM 17.9 dB My Voron Switchwire Components list: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
01.01.2021 - Voron Switchwire - Afterburner - Hotend Housing - Dragon Hotend
12/30/2020 at 08:03 • 0 commentsVoron Afterburner - 3D Printed Dragon Housing 24V 50W Heater Cartridge (left) and ATC Semitec 104GT-2 Thermistor (right)
https://hackaday.io/project/174810/componentsHigh Flow TriangleLab Dragon Hotend inside Voron Afterburner Hotend Housing Voron Switchwire - Afterburner - Hotend Housing with Dragon Hotend -
29.12.2020 - Voron Switchwire - Afterburner - Extruder
12/29/2020 at 12:54 • 0 commentsVoron Switchwire - Afterburner - Extruder Voron Switchwire - Afterburner - Extruder Gears Voron Switchwire - Afterburner - Extruder Body Assembled Trianglelab BMG Direct Drive Basic kit
29.12.2020 - Voron Switchwire - Afterburner - Extruder Motor
12/28/2020 at 14:56 • 0 commentsVoron Switchwire - Afterburner - Extruder Stepper Motor Voron Switchwire - Afterburner - Extruder Stepper Motor - Back View Voron Switchwire - Afterburner - Extruder Motor ready to assembly on 3D Printer 1. StepperOnline NEMA 17 Stepper Motor 17HS08-1004S 20mm 1A 16Ncm(22.6oz.in) 2. 3D Printed Extruder Motor Back Plate with Bolts and M3 insert nuts
3. 3D printed Connector Cover and Cable Chain Anchor. Two of four bolts M3x14mm that came with the Stepper Motor will be swapped to M3x20mm
